zimny 3 Posted October 4, 2019 Posted October 4, 2019 Hi, I'm wondering if you are planning to add proper support for android tv box remote to your Emby app? For know there is almost not possible navigate through your app by original box remote. User don't have any idea where cursor is currently in the app. Users with touch screen probably don't have this problem. Need to using mouse all the time. Kodi have very good support for remote control for example. Thank you,
Luke 42246 Posted October 4, 2019 Posted October 4, 2019 Hi, what emby app are you using? We have a dedicated Android TV app: https://emby.media/emby-for-android-tv.html
zimny 3 Posted October 4, 2019 Author Posted October 4, 2019 Hi I'm using official app from Google store
Solution zimny 3 Posted October 4, 2019 Author Solution Posted October 4, 2019 OK got it ! Didn't know that is second app in store dedicated for tv boxes. Thank you for support 1
