Luke 42216 Posted November 8, 2019 Posted November 8, 2019 This should be resolved for the next release of Emby Server. Thanks.
mbc0 68 Posted November 27, 2019 Posted November 27, 2019 Hi @@Luke, thanks for the latest update but unfortunately the problem still exists
Luke 42216 Posted November 27, 2019 Posted November 27, 2019 Hmm, ok, we'll have to take another look. If you add new content to your library, does the icon show on that?
mbc0 68 Posted November 27, 2019 Posted November 27, 2019 Hmm, ok, we'll have to take another look. If you add new content to your library, does the icon show on that? I am sorry, do you mean add new content whilst a recording is in progress?
Luke 42216 Posted November 27, 2019 Posted November 27, 2019 Ah ok, sorry i missed that. So these icons are only happening when a recording is in progress, and not all the time?
apefray 4 Posted November 27, 2019 Author Posted November 27, 2019 Hi Luke, Yes, as per my op, it only happens when there is a scheduled recording. Everything works fine when it isn't recording. C
mbc0 68 Posted November 27, 2019 Posted November 27, 2019 Ah ok, sorry i missed that. So these icons are only happening when a recording is in progress, and not all the time? Yup! only when recording
Luke 42216 Posted January 31, 2020 Posted January 31, 2020 We are looking into it. Thanks for following up.
mickle026 653 Posted January 31, 2020 Posted January 31, 2020 @@mickle026 All movie types in all movie libraries are showing as recording when a recording is active and a library scan is in progress. (to be clear if nothing is recording this doesnt happen, if no library scan is in progress this doesn't happen) This has been happening for quite a few betas now and I am thinking no one has reported it. To make this worse, the server dashboard shows everything thats is in the recorded (past tense) library as recording aswell. (Already saved in the hdd) In the image below, there is only ONE recording in progress. "Escape to the Chateau" - UK Channel 4 , notice how the sub title is the same for everything.... 1
Happy2Play 9806 Posted January 31, 2020 Posted January 31, 2020 (edited) Pretty sure this is this topic https://emby.media/community/index.php?/topic/78116-strange-icon-and-naming/ Well you go merged Edited January 31, 2020 by Happy2Play
mickle026 653 Posted February 1, 2020 Posted February 1, 2020 @@Luke , Has this issue been identified? Like I said it only seems to happen during an active library scan. Im running beta 4.4.0.11. Its a pain in the behind because I cannot see what is actually recording without stopping the running scan and sometimes they take ages to actually stop.
mbc0 68 Posted February 1, 2020 Posted February 1, 2020 I think it is a slightly different issue than mine, same result but happens to me when recording anything without any library scans
mickle026 653 Posted February 1, 2020 Posted February 1, 2020 I think it is a slightly different issue than mine, same result but happens to me when recording anything without any library scans Might be the same issue causing it though.
