apefray 4 Posted October 4, 2019 Posted October 4, 2019 (edited) Hi, I recently came back to find find that my unraid server had shut down and when restarted emby now shows a red circle icon on all the movies and all the movies in the library have the same name, for example: All the movies are shown with the red circle, top right hand corner and the same title 'Targoviste Castle and Hoia-Baciu Forest'. However, if I click into the movie, then the title is correct: What does the red circle mean, and why is emby showing the wrong title in the library, but not when you click on a movie? I have tried scanning the library, and refreshing the metadata, but neither has fixed the title and the red icon is still being shown? Just in case it helps, I run emby v4.2.1.0 in a docker through Unraid. It looks like all the other libraries are fine, not showing the red icon and showing the correct title within the library. Edit: Just checked all the various movie folders and they all show the same, red circle and wrong title. The only place where it is correct for the movies is within the collections library. No red circle or incorrect title?? Cheers C Edited October 4, 2019 by apefray
Luke 42216 Posted October 11, 2019 Posted October 11, 2019 @@apefray are you still running into this?
apefray 4 Posted October 14, 2019 Author Posted October 14, 2019 Hi Luke, Sorry for the late reply, I didn't see you had replied. No, I resolved the issue by removing the libraries, then re-adding them, emby then re-scanned my entire movie collection and all seems correct now. If I'm correct, the red icon is the record icon as used on live TV, but where it got the title from, I have no idea as I have never had any movie with that title.
Luke 42216 Posted October 14, 2019 Posted October 14, 2019 That's interesting, thanks for the feedback. We'll try to find out why it happened.
apefray 4 Posted October 21, 2019 Author Posted October 21, 2019 (edited) Hi Luke, Its happend again, but this time the title is 'Star of India'. Never heard of it nor do I have a movie of said name: So I did a bit of rooting around the log and have found this (sorry, I couldn't work out how to imbed a log file): 2019-10-21 15:59:55.309 Info HttpServer: HTTP Response 204 to **.**.**.**. Time: 5ms. http://******.******.***:****/emby/Sessions/Playing/Progress 2019-10-21 15:59:59.999 Info LiveTV: Recording timer fired for Ghost Adventures. 2019-10-21 16:00:00.069 Info HttpClient: GET https://www.thetvdb.com/api/GetSeriesByRemoteID.php?zap2it=EP01370926&language=en 2019-10-21 16:00:00.759 Info HttpClient: GET https://www.thetvdb.com/api/GetSeriesByRemoteID.php?zap2it=SH01370926&language=en 2019-10-21 16:00:01.356 Info HttpClient: GET https://www.thetvdb.com/api/GetSeries.php?seriesname=Ghost+Adventures&language=en 2019-10-21 16:00:02.000 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/83929/all/en.zip 2019-10-21 16:00:02.528 Info App: MovieDbProvider: Finding id for item: Ghost Adventures 2019-10-21 16:00:02.528 Info HttpClient: GET https://api.themoviedb.org/3/search/tv?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Ghost+Adventures&language=en 2019-10-21 16:00:02.938 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&s=Ghost+Adventures&type=series 2019-10-21 16:00:03.084 Info LiveTV: Getting media sources for recording from channel 159986 159986 2019-10-21 16:00:03.086 Info LiveTV: Opening live stream for recording from channel 159986 159986 2019-10-21 16:00:03.086 Info LiveTvManager: Opening channel stream from Emby, external channel Id: hdhr_17 2019-10-21 16:00:03.086 Info LiveTV: Streaming Channel hdhr_17 2019-10-21 16:00:03.086 Info HdHomerunHost: GetChannelStream: channel id: hdhr_17. stream id: native_67b13de842904e123ccd1cbba07c86e9_e6544e22eefa32acd289b1bed58adcd4 profile: native 2019-10-21 16:00:03.124 Info SharedHttpPipelineSource: Opening SharedHttpPipelineSource Live stream from http://**.**.**.**:****/auto/v17 2019-10-21 16:00:03.124 Info HttpClient: GET http://**.**.**.**:****/auto/v17 2019-10-21 16:00:03.471 Info HttpClient: Http response 200 from http://**.**.**.**:****/auto/v17 after 346ms. HeadersServer=HDHomeRun/1.0, Connection=close, Cache-Control=no-cache, Pragma=no-cache, transferMode.dlna.org=Streaming, Date=Mon, 21 Oct 2019 15:00:03 GMT, X-HDHomeRun-Resource=tuner0 2019-10-21 16:00:03.471 Info SharedHttpPipelineSource: Beginning SharedHttpPipelineSource stream to /config/transcoding-temp/ea219aebc44e48859512a339ab6ddd7e.ts 2019-10-21 16:00:03.472 Info HdHomerunHost: Live stream opened after 385.494ms 2019-10-21 16:00:03.472 Info LiveTV: Returning mediasource streamId native_67b13de842904e123ccd1cbba07c86e9_e6544e22eefa32acd289b1bed58adcd4, mediaSource.Id native_67b13de842904e123ccd1cbba07c86e9_e6544e22eefa32acd289b1bed58adcd4, mediaSource.LiveStreamId null 2019-10-21 16:00:03.476 Info MediaSourceManager: Live tv media info probe took 0.0037783 seconds 2019-10-21 16:00:03.476 Info MediaSourceManager: Live stream opened: {"Protocol":"Http","Id":"native_67b13de842904e123ccd1cbba07c86e9_e6544e22eefa32acd289b1bed58adcd4","Path":"http://127.0.0.1:8096/LiveTv/LiveStreamFiles/ea219aebc44e48859512a339ab6ddd7e/stream.ts","Type":"Default","Container":"mpegts","IsRemote":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDi rectPlay":false,"IsInfiniteStream":true,"RequiresOpening":true,"RequiresClosing":true,"LiveStreamId":"06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_67b13de842904e123ccd1cbba07c86e9_e6544e22eefa32acd289b1bed58adcd4","RequiresLooping":false,"SupportsProbing":false,"MediaStreams": [{"Codec":"mpeg2video","TimeBase":"1/90000","CodecTimeBase":"1/25","VideoRange":"SDR","DisplayTitle":"576p MPEG2VIDEO","IsInterlaced":false,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":576,"Width":544,"AverageFrameRate":25,"RealFrameRate":25,"Profile":"Main","Type":"Video","AspectRatio":"16:9","Index":- 1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuv420p","Level":8,"IsAnamorphic":false},{"Codec":"mp2","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"MP2 stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":128000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","Level":0}],"Formats": [],"Bitrate":128000,"RequiredHttpHeaders":{},"ReadAtNativeFramerate":false} 2019-10-21 16:00:03.478 Info LiveTV: Will record to /config/data/livetv/recordings/Ghost Adventures (2008)/Season 12/Ghost Adventures S12E06 Star of India.ts for 59.942031445 minutes. 2019-10-21 16:00:05.230 Info HttpServer: HTTP OPTIONS http://******.******.***:****/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; Linux armv7l) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.172094 2019-10-21 16:00:05.230 Info HttpServer: HTTP Response 200 to **.**.**.**. Time: 0ms. http://******.******.***:****/emby/Sessions/Playing/Progress 2019-10-21 16:00:05.299 Info HttpServer: HTTP POST http://******.******.***:****/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; Linux armv7l) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.172094 2019-10-21 16:00:05.369 Info HttpClient: GET https://emby.tmsimg.com/assets/p12511035_b_v7_ab.jpg 2019-10-21 16:00:05.370 Info HttpServer: HTTP Response 204 to **.**.**.**. Time: 71ms. http://******.******.***:****/emby/Sessions/Playing/Progress 2019-10-21 16:00:05.370 Info LiveTV: Copying recording stream to file /config/data/livetv/recordings/Ghost Adventures (2008)/Season 12/Ghost Adventures S12E06 Star of India.ts 2019-10-21 16:00:05.853 Info LiveTV: Triggering refresh on /config/data/livetv/recordings/Ghost Adventures (2008)/Season 12/Ghost Adventures S12E06 Star of India.ts So it appears a live TV Recording is triggering the name change and for the red icon to appear. I have a HDHOMERUN Quatrro running through Emby and using the Emby TV Guide. As you can see, the title 'Star of India' is mentioned in that part of the log, and maybe linked to TVDB???? Edited October 21, 2019 by apefray
chef 3811 Posted October 21, 2019 Posted October 21, 2019 Sorry, you public IP is in plain text above.
apefray 4 Posted October 21, 2019 Author Posted October 21, 2019 Whoops, thanks for pointing that out. Thought I had caught them all. Should be sorted now though.
apefray 4 Posted October 21, 2019 Author Posted October 21, 2019 Also just to confirm this is the Live TV recording schedule that seems to be causing the issue: The times don't appear to tie up with the recordings and emby, but that could be a mute point.
apefray 4 Posted October 21, 2019 Author Posted October 21, 2019 (edited) Lol, and we have a name change: Guess another Live TV Recording is about to start. Actually more worryingly, even though there are Live TV Programs scheduled, the ones in the past never end up in the TV Recording folder anyway, its completely blank. Edited October 21, 2019 by apefray
apefray 4 Posted October 21, 2019 Author Posted October 21, 2019 Luke, I have now and that has resolved the issue. Any idea why this is happening?
apefray 4 Posted October 21, 2019 Author Posted October 21, 2019 Yes, they were scheduled recordings. When emby starts to record the program from the schedule, thats where the issue arises.
mbc0 68 Posted October 30, 2019 Posted October 30, 2019 (edited) Hi, When there is an active recording my Movie library, Next Up etc all have the recording icon next to them and the Movie title disappears leaving just the year? Screenshots and logs attached :-) Also the active recording image is an impossibly large icon! EmbyServer 4.2.1.0 / unRAID Docker embyserver.zip Edited October 30, 2019 by mbc0
ebr 16313 Posted October 30, 2019 Posted October 30, 2019 Sounds like the same issue as here: Strange Icon and Naming
mbc0 68 Posted October 30, 2019 Posted October 30, 2019 Yes, it seems to be! I will head over there.. thanks @@ebr
mbc0 68 Posted October 30, 2019 Posted October 30, 2019 Hi, I have a very similar issue posted here with logs and screenshots ( https://emby.media/community/index.php?/topic/78831-when-live-tv-recording-in-progress-movie-library-display-corrupts/?p=801558 ) the issue seems to resolve itself after the recording has finished Many Thanks
davedick 19 Posted November 2, 2019 Posted November 2, 2019 @@davedick Tonight I noticed that the library media is showing red record series and everything shows the same title, but posters are correctHow would I fix this? I'm attempting a library refresh now
mbc0 68 Posted November 2, 2019 Posted November 2, 2019 Any idea on what I can do about this issue please? My original post has been deleted but it is the same issue
ebr 16313 Posted November 3, 2019 Posted November 3, 2019 Hi. Your post wasn't deleted - it was merged with this topic because they are the same issue. Thanks.
mbc0 68 Posted November 5, 2019 Posted November 5, 2019 Thanks @@ebr hopefully someone can take a look at it as the interface is unusable when a TV recording is in progress. Cheers
Mbppg 3 Posted November 5, 2019 Posted November 5, 2019 Same issue here. I have restarted the Emby server but right as a recording was starting as well. So having to wait until all recording are completed and I will retry again.
Mbppg 3 Posted November 5, 2019 Posted November 5, 2019 (edited) Okay so what I found is that I was recording Running Wild with Bear Gryles. I also found that in the recording directory I ended up with two folders with the same name the only difference is was one was Running Wild With Bear Gryles and the was Running Wild with Bear Gryles. I do have MCE buddy running to convert the TS files into mp4 and also renaming the files when they are completed. I think somehow Emby and the folder structure got confused and caused the weird issue show above. Once my recordings were completed, everything was back to normal. I have copied over the files into the Running Wild With Bear Gryles and removed the duplicate folder and will see if it happens again. But for now everything looks fine. Edited November 5, 2019 by Mbppg
mbc0 68 Posted November 7, 2019 Posted November 7, 2019 (edited) Hi, Can someone please take a look at this please? every time something records my whole library becomes the name of what is being recorded with a red dod on the artwork and timeline as well. (pictures and logs posted on post #14) Currently my entire library is Peppa Pig! Doesn't seem to effect Music or TV Shows but it does effect next up tv shows.. Edited November 7, 2019 by mbc0
