Damien_ 30 Posted October 4, 2019 Posted October 4, 2019 Hi, I've had this reoccurring issue for some time. I'll get everything corrected and a month or two later it returns. Basically Emby starts using backdrop images for movie and tv posters. No clue why or why it starts reoccurring after a certain amout of time. I've tried a few different things- I stopped refreshing the artwork automatically once it was corrected. I made sure that I also had a local copy in the same folder of the correct artwork for posters from TMDB - nothing has worked. Has anyone come across this? Any guidance would be very appreciated. Thanks
Luke 42239 Posted October 4, 2019 Posted October 4, 2019 Hi, the reason for this is because that's the only image you have. Try adding a poster to those titles and then you will see that instead. Please let us know if this helps. Thanks.
Damien_ 30 Posted October 4, 2019 Author Posted October 4, 2019 Hi, the reason for this is because that's the only image you have. Try adding a poster to those titles and then you will see that instead. Please let us know if this helps. Thanks. Sorry I probably wasnt clear. These all have artwork included. Movies, TV shows all have artwork. Movies are setup: /Godfather (1972) Godfather (1972).1080p.mkv poster.jpg backdrop.jpg fanart.jpg Also keep in mind It's not just new media when this happens. It's changing stuff that's already been scanned in. Thanks
Luke 42239 Posted October 4, 2019 Posted October 4, 2019 Please try running a library scan and see if that helps. Thanks.
