paulson121591 5 Posted October 3, 2019 Posted October 3, 2019 (edited) Is there a special way to scan a Library that i'm not aware of? certain songs I add to my music library. show up but if I try to play them it says " Playback Error No compatible streams are currently available. Please try again later or contact your system administrator for details. What could cause this? the file works fine if i play it directly on my server. but anywhere else I get this error. any advise would help. Edited October 3, 2019 by paulson121591
Happy2Play 9806 Posted October 3, 2019 Posted October 3, 2019 Is there a special way to scan a Library that i'm not aware of? certain songs I add to my music library. show up but if I try to play them it says " Playback Error No compatible streams are currently available. Please try again later or contact your system administrator for details. What could cause this? the file works fine if i play it directly on my server. but anywhere else I get this error. any advise would help. What format is the music in? I know there are topics like this for "flac" containing improper id3 tags.
Luke 42217 Posted October 3, 2019 Posted October 3, 2019 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. thanks !
paulson121591 5 Posted October 3, 2019 Author Posted October 3, 2019 What format is the music in? I know there are topics like this for "flac" containing improper id3 tags. It is a FLAC file. as is most of my music. But I fixed it i believe... I think this was the issue I moved the files from the C drive to my D Drive (D drive is my server drive). when I said "the file works fine if i play it directly on my server" I was playing from my C Drive like a bimbo. A moment ago I attempted to play a song that was not working directly from the D Drive it said " File Corrupted" so some how in the transfer from my C drive to D drive the file became corrupted. I transfer the file again and now it is working fine Thanks for the reply Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. thanks ! thanks for the direction. I'll keep that in mind in the future
