MAR091645 0 Posted October 2, 2019 Posted October 2, 2019 so I am prompted for a pin when signing in on the Android app. After I get the pin I enter it and it says it's submitted but nothing happenes. Just prompts me to do the same dang thing again and again and again. What gives?
Luke 42244 Posted October 4, 2019 Posted October 4, 2019 Hi there @@Lorties, are you trying to connect to your Emby Server, or someone else's server?
MAR091645 0 Posted October 12, 2019 Author Posted October 12, 2019 Hi Luke? Mine, local from Emby Theater.
Luke 42244 Posted October 12, 2019 Posted October 12, 2019 Have you setup Emby Connect with your Emby Server? You need to do that first before you can use the pin code sign in feature.
