ebr 16338 Posted February 1, 2020 Posted February 1, 2020 Yes it works as long as I use the movie title as the folder inside the 'Movies' folder. Doesn't work if I just put the movie and the trailer in the 'Movies' folder. Found a batch script which creates and moves all the titles to their own folder. I still think it should work with more than one movie in a folder - but the names have to be exactly right. Did you check that?
dcol 177 Posted February 1, 2020 Posted February 1, 2020 (edited) I still think it should work with more than one movie in a folder - but the names have to be exactly right. Did you check that? Yes checked it more than once and re-scan the library. Only started working after I created the new folder with the movie title and moved the movie and trailer in it. Now the trailer button is available in the movie details page. Edited February 1, 2020 by dcol
ebr 16338 Posted February 1, 2020 Posted February 1, 2020 What were the exact names of all the items in question?
dcol 177 Posted February 1, 2020 Posted February 1, 2020 Movie is '6 Underground.2019.mp4' and trailer is '6 Underground.2019-trailer.mp4'
Spaceboy 2573 Posted February 1, 2020 Posted February 1, 2020 Works for me where I’ve got multiple versions of a movie in the same folder and the trailer
dcol 177 Posted February 4, 2020 Posted February 4, 2020 (edited) nope, just tried it again. If I put the movie and trailer in the folder with all the movies, the trailer does not appear. If I create a new folder with the movie name and put the files in there, it works. This is on FireTV only, Android is fine. Here is my format \Movies\Latest\movie&Trailer.mp4 here (does not work) \Movies\Latest\movie name\movie&Trailer.mp4 here (does work) Also, you have to use the actual movie name for the folder name or the metadata is wrong. Now maybe this is the required format, which is fine. But what others have said in this post doesn't work in FireTV. Edited February 4, 2020 by dcol
Luke 42246 Posted February 4, 2020 Posted February 4, 2020 You can learn how to name your trailer files in our wiki: https://support.emby.media/support/solutions/articles/44001159193-trailers
dcol 177 Posted February 4, 2020 Posted February 4, 2020 You can learn how to name your trailer files in our wiki: https://support.emby.media/support/solutions/articles/44001159193-trailers Yes. Figured that out and working now. But you must follow that structure, you can't group it with other movies as others have said worked.
NeilD7744 3 Posted March 30, 2020 Posted March 30, 2020 have a look at this piece of software. After youtube stopped working for me in Emby as you mention above, I used this software (which ive been using for years) to auto download trailers into my local movie library. It works ok for me... http://mediacentermaster.com/ Thanks.
dcol 177 Posted March 30, 2020 Posted March 30, 2020 (edited) have a look at this piece of software. After youtube stopped working for me in Emby as you mention above, I used this software (which ive been using for years) to auto download trailers into my local movie library. It works ok for me... http://mediacentermaster.com/ Thanks. Has potential, but you have to pay for the You Tube trailers downloading. I bought a one month and will test it out. Edited March 30, 2020 by dcol
dcol 177 Posted March 30, 2020 Posted March 30, 2020 Tested this program out. Could not get any trailers from even the latest movies. Not a very easy program to use, but if I figure it out may have some potential.
NeilD7744 3 Posted March 31, 2020 Posted March 31, 2020 Tested this program out. Could not get any trailers from even the latest movies. Not a very easy program to use, but if I figure it out may have some potential. Would it help if i made a youtube tutorial? Its a complex piece of software, but once its up and running i found it to be very useful. I've got this software auto scanning on a regular basis, so any recorded movies from Emby which go into my library should then been seen by Media Center Master and the trailers added. Its a bit of a work around as the link to youtube as mentioned earlier in this post would be much better and easier. Id say i have about 95% success rate with trailers added locally. If Media Center Master does not auto download the trailer then yo can prompt and give it a direct youtube link to download from. The directories within Emby need to be setup correctly (as i found out) else it will not work correctly. Also make sue within Emby you have "scheduled tasks" setup correctly - else a trailer may have been downloaded correctly, but will not display correctly as the library needs to be re-scanned / updated.
dcol 177 Posted March 31, 2020 Posted March 31, 2020 Would it help if i made a youtube tutorial? Its a complex piece of software, but once its up and running i found it to be very useful. I've got this software auto scanning on a regular basis, so any recorded movies from Emby which go into my library should then been seen by Media Center Master and the trailers added. Its a bit of a work around as the link to youtube as mentioned earlier in this post would be much better and easier. Id say i have about 95% success rate with trailers added locally. If Media Center Master does not auto download the trailer then yo can prompt and give it a direct youtube link to download from. The directories within Emby need to be setup correctly (as i found out) else it will not work correctly. Also make sue within Emby you have "scheduled tasks" setup correctly - else a trailer may have been downloaded correctly, but will not display correctly as the library needs to be re-scanned / updated. Yes a YouTube tutorial would be nice. I do have the folders setup correctly, it does stick all the metadata files in there but the log gives me errors for the trailers. Says YouTube is not in the metadata, but also says that an iTunes trailer is available which does me no good. Also, I do not want all that extra metadata files in the folder, just the trailer. Ideally I want it to work like this. Scan my folders for missing trailers and add them when missing. That's all I am looking for.
NeilD7744 3 Posted March 31, 2020 Posted March 31, 2020 I dont think it matters where the trailers are grabbed from, they are just downloaded from whatever website (youtube, itunes...etc) and stored as an MP4 within your associated movie sub folder. You can turn off most of the other stuff so MCM will not download & compile loads and loads of artwork etc. I believe you have to have the xml / nfo files in with the movie & trailer etc as part of MCM's database (however i maybe incorrect). When you intially load all your movies within MCM they will probably show up in red. You need to sort out the settings as you want them (for what artwork etc to download) and then enable downloading of trailers. Under the 'media' menu within MCM, click 're-fetch all media titles' and let the software do its thing. It should auto populate movies. Mine works like this with no issues. The log on the RHS of MCM may give errors about trailers initially, this is because MCM needs to compile your database of movie (turn from a red list into a white list). As the data is fetched and movie titles turning from red to white within the MCM list, a loading bar should appear and queue up trailers to download. Failing that... I have no idea... try and find an older APK for YouTube & side load it? Or, (after having a quick Google seach) learn about scripts and python to set something up?
dcol 177 Posted March 31, 2020 Posted March 31, 2020 Ok, Just need to figure out what does what. Seems to be working now. A tutorial would be really helpful. This software is loaded with features.
NeilD7744 3 Posted April 1, 2020 Posted April 1, 2020 Ok... bear with me.... I did make a video yesterday but as you already have managed to get trailers to download it probably wont cover other things. I will make another video and send you a link - I will wipe / reset my database and go through it from scratch (or at least show what works for me). Thanks.
dcol 177 Posted April 1, 2020 Posted April 1, 2020 Some of the trailers did not convert and are still .mov container. I have started 'find missing trailers' again, now that all the movies are yellow, and have metadata. ffprobe.exe finally downloaded this morning.
