paulson121591 5 Posted October 3, 2019 Posted October 3, 2019 (edited) h Edited October 3, 2019 by paulson121591
Q-Droid 1002 Posted October 3, 2019 Posted October 3, 2019 Okay, so for anyone that comes across this in the future: for Spectrum Routers I went into "Access Control" then went to the "DMZ" tab I click "Enable" that gave me a drop down. I selected the name of the computer my server is installed on click apply I was then able to access the server remotely. Admins please correct me if I am wrong but the troubleshooting guide did not include anything on DMZ settings. You may want to add that in. Thank you for trying to help. Nope. What you have done is effectively moved your computer from your internal network to the internet. All unsolicited traffic from the internet will be routed to that device. Nobody should do this and especially people who don't know what they are doing.
paulson121591 5 Posted October 3, 2019 Posted October 3, 2019 Nope. What you have done is effectively moved your computer from your internal network to the internet. All unsolicited traffic from the internet will be routed to that device. Nobody should do this and especially people who don't know what they are doing. Yes i'm trying to figure out how to fix it correctly any advice?
paulson121591 5 Posted October 3, 2019 Posted October 3, 2019 Okay thought this was solved but it was a band-aid I have a spectrum router i can not connect to it remotely i tried to update the port forwarding. and it did not help canyouseme.com can in fact NOT see me the only way i can connect remotely is by Enabling DMZ in my router, which is unsafe the fire wall on my computer is not the issue I completely shut it off to test if that was the issue, i still could not connect. Can someone please give me an idea on what else i can try?
Luke 42197 Posted October 3, 2019 Posted October 3, 2019 @@paulson121591, I've merged your new topic into here as it will be easier for everyone involved to help you in once place since this contains all of the previous back story. Thanks !
Q-Droid 1002 Posted October 3, 2019 Posted October 3, 2019 (edited) The IP address on the Emby server should be static (manually assigned) or reserved (via DHCP reservation on the router/gateway) so that the mapping doesn't change. The port forwarding you posted before looked OK, IPs were hidden. Was the internal IP also selected from a list, same as with the DMZ config? If the DMZ option worked then the port forwarding might not be quite right. I would almost rule out firewall on the server because the DMZ worked. Edited October 3, 2019 by Q-Droid
Q-Droid 1002 Posted October 3, 2019 Posted October 3, 2019 As discussed in a PM I am able to connect to @@qlinyear WAN/port address and get to the login page, so I really have no clue why they can't connect to their WAN/port. From work I would have to guess and say possibly the work network is blocking that port traffic. But from home there should be no issue that I can really think of, unless they have multiple networks on their LAN. Some routers don't allow NAT loopback connections.
paulson121591 5 Posted October 3, 2019 Posted October 3, 2019 (edited) The IP address on the Emby server should be static (manually assigned) or reserved (via DHCP reservation on the router/gateway) so that the mapping doesn't change. The port forwarding you posted before looked OK, IPs were hidden. Was the internal IP also selected from a list, same as with the DMZ config? If the DMZ option worked then the port forwarding might not be quite right. I would almost rule out firewall on the server because the DMZ worked. no it was not a drop down however the "internal host" is the same IP as the IP form the DMZ settings.. is it safe to post my ip? i know thats probably a dumb question also the IP is reserved Edited October 3, 2019 by paulson121591
Happy2Play 9802 Posted October 3, 2019 Posted October 3, 2019 Okay thought this was solved but it was a band-aid I have a spectrum router i can not connect to it remotely i tried to update the port forwarding. and it did not help canyouseme.com can in fact NOT see me the only way i can connect remotely is by Enabling DMZ in my router, which is unsafe the fire wall on my computer is not the issue I completely shut it off to test if that was the issue, i still could not connect. Can someone please give me an idea on what else i can try? What is the model of router? Many have reported disabling the Windows firewall has no effect. What inbound firewall rules do you have for private and public networks for Embyserver.exe and port 8096?
Happy2Play 9802 Posted October 3, 2019 Posted October 3, 2019 (edited) no it was not a drop down however the "internal host" is the same IP as the IP form the DMZ settings.. is it safe to post my ip? i know thats probably a dumb question also the IP is reserved You are better off working in a PM if you want someone to assist with WAN address. But I see the one you had in previous post fails on port checker sites. Edited October 3, 2019 by Happy2Play
Q-Droid 1002 Posted October 3, 2019 Posted October 3, 2019 no it was not a drop down however the "internal host" is the same IP as the IP form the DMZ settings.. is it safe to post my ip? i know thats probably a dumb question also the IP is reserved Ok, I hate to ask this but have you tried rebooting the router after the port forwarding change? Not good practice to post IP.
paulson121591 5 Posted October 4, 2019 Posted October 4, 2019 Ok, I hate to ask this but have you tried rebooting the router after the port forwarding change? Not good practice to post IP. Yeah. I've rebooted it. thanks for the advice What is the model of router? Many have reported disabling the Windows firewall has no effect. What inbound firewall rules do you have for private and public networks for Embyserver.exe and port 8096? it is a Sagemcom RAC2V1A As far as my Fire wall goes this is what i have .... and so i think i'm good there
paulson121591 5 Posted October 4, 2019 Posted October 4, 2019 So could it be my DLNA settings on my router?
Q-Droid 1002 Posted October 4, 2019 Posted October 4, 2019 I would say no, and leave it disabled. Is automatic port mapping disabled in Emby? It should be off. Is UPnP disabled on the router? Should also be off.
paulson121591 5 Posted October 4, 2019 Posted October 4, 2019 I would say no, and leave it disabled. Is automatic port mapping disabled in Emby? It should be off. Is UPnP disabled on the router? Should also be off. Port mapping was on it is now off; still no luck UPnP is off and has been
Q-Droid 1002 Posted October 4, 2019 Posted October 4, 2019 Are you still trying canyouseeme to test it?
paulson121591 5 Posted October 4, 2019 Posted October 4, 2019 (edited) Are you still trying canyouseeme to test it? yeah no change. Hmm, I just checked port "80" which i believe should work and i also got it can not see me.. is that normal? Edited October 4, 2019 by paulson121591
Q-Droid 1002 Posted October 4, 2019 Posted October 4, 2019 It's normal for port 80 to fail from the WAN side. All ports should fail from WAN except the ones explicitly mapped to LAN via forwarding.
paulson121591 5 Posted October 4, 2019 Posted October 4, 2019 Well then I feel defeated. I have now clue where to go from here. Admins are gone. I've tinkered with almost every single setting on my router. the only thing that works is put my server PC into the DMZ.which is a bad idea I guess.. 2 days is just too much time to make this little progress. I just feel like i wasted $4 dollars and 2 days.
Q-Droid 1002 Posted October 4, 2019 Posted October 4, 2019 I'm out of ideas too. If the router WAN IP matches canyouseeme and the Emby detected external IP then I don't know what else to check. Everything else appears to be right. Go get some free tacos so you can break even on the $4. 1
paulson121591 5 Posted October 5, 2019 Posted October 5, 2019 Okay ready for this? I put an "external IP" into the port forwarding, I was not supposed to. It was that simple 1
Q-Droid 1002 Posted October 5, 2019 Posted October 5, 2019 Okay ready for this? I put an "external IP" into the port forwarding, I was not supposed to. It was that simple An external IP? So what does that port forwarding rule look like now?
Happy2Play 9802 Posted October 5, 2019 Posted October 5, 2019 Are you saying you were manually entered your WAN address and router did not do it automatically?
Solution paulson121591 5 Posted October 7, 2019 Solution Posted October 7, 2019 (edited) An external IP? So what does that port forwarding rule look like now? see below i think this should clear it up Are you saying you were manually entered your WAN address and router did not do it automatically? yes this is correct Sorry let me update this to be as clear as possible. I hope I can help some one in the future On my router options I have a few boxes I can fill in 1."Custom service name" 2."Service" 3."Protocol" 4."External host" 5"External Port" 6."Internal host" 7."Internal Port" as shown here... So... the way i filled it out the first time was incorrect. I entered the "Remote access IP" that i got from the Emby dashboard into the "external IP" this was just a dumb mistake. see below for the CORRECT way to fill it out IF you have this router or something like it as you can see External host should be blank. I believe this is the correct way to have it AGAIN if anyone sees an issue with this please correct me also... If you come across this in the future please DO NOT take my earlier advice of putting your server into a DMZ I don't know how to delete a post but I would if I could. Hope this helps someone! Thanks for everyone's help Edited October 7, 2019 by paulson121591 3 1
