rechigo 367 Posted October 1, 2019 Posted October 1, 2019 Server: 4.3.0.10 Clients: 3.0.82 (android) I noticed that if audio is transcoding, whether due to a congested cell network or forced via the playback settings, it still shows under the web dashboard as direct play, when it is not. Also, when are the seasonal themes supposed to be set if we have that option checked? I know there is a Halloween theme, but it hasn't automatically been set as my theme. Are seasonal themes for the WHOLE month of October or just Halloween day?
rechigo 367 Posted October 2, 2019 Author Posted October 2, 2019 It's typically just the day of the holiday. And for the audio transcoding?
ebr 16313 Posted October 2, 2019 Posted October 2, 2019 it still shows under the web dashboard as direct play, when it is not. Are you sure it doesn't say "Direct Stream" or just "Direct"? We key off of video. If video is not being converted then we consider it as direct because audio conversions are usually trivial.
Sammy 791 Posted October 2, 2019 Posted October 2, 2019 It's typically just the day of the holiday.Last year it was at least 2 or 3 weeks of October and then again in December. Sent from my SM-G960U1 using Tapatalk
ebr 16313 Posted October 2, 2019 Posted October 2, 2019 For the December Holidays, it usually is over several days. For Halloween, though, it is only a day or two. You can select it manually any time you wish though.
rechigo 367 Posted October 2, 2019 Author Posted October 2, 2019 Are you sure it doesn't say "Direct Stream" or just "Direct"? We key off of video. If video is not being converted then we consider it as direct because audio conversions are usually trivial. Yes, it does say Direct
