saajan4u 79 Posted June 6, 2014 Posted June 6, 2014 Hello I just got my 1st Chrome cast yesterday.. its great works fine love it but cant seem to play anything using the Android App all i get is the blues spinning wheel and nothing happens I don't see any changes in the servers task manager either.. don't know what I'm doing wrong... your help is much appreciated cheers Saj
CBers 7554 Posted June 6, 2014 Posted June 6, 2014 Blue Spinning Wheel on the TV? Are you waiting for the Mb3 page to be displayed on the TV before you press play in the Android app? Check the logs on the server and see if there is a transcoded log file. Might be worth posting it and the corresponding server log.
saajan4u 79 Posted June 6, 2014 Author Posted June 6, 2014 yeah blue spinning wheel on TV. yeah the mb android app does connect and says I can q up the media. can you please tell me where can I find the server log. cheers for your help so far
CBers 7554 Posted June 6, 2014 Posted June 6, 2014 Server and transcode logs are in: %appdata%\MediaBrowser-Server\logs on the PC where MB server is running.
saajan4u 79 Posted June 6, 2014 Author Posted June 6, 2014 cheers for that C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\ffmpeg\20140506\ffmpeg.exe -i "http://api.soundcloud.com/tracks/152659144/stream?client_id=78fd88dde7ebf8fdcad08106f6d56ab6" -threads 2 -vn -ab 128000 -ac 2 -id3v2_version 3 -write_id3v1 1 -y "C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\transcoding-temp\87545491-7fd8-3588-da0d-17b0b1cecdfa.mp3" ffmpeg version N-62994-g2baf1c8 Copyright © 2000-2014 the FFmpeg developers built on May 5 2014 22:01:55 with gcc 4.8.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-decklink --enable-zlib libavutil 52. 81.100 / 52. 81.100 libavcodec 55. 60.103 / 55. 60.103 libavformat 55. 37.102 / 55. 37.102 libavdevice 55. 13.101 / 55. 13.101 libavfilter 4. 5.100 / 4. 5.100 libswscale 2. 6.100 / 2. 6.100 libswresample 0. 18.100 / 0. 18.100 libpostproc 52. 3.100 / 52. 3.100 Input #0, mp3, from 'http://api.soundcloud.com/tracks/152659144/stream?client_id=78fd88dde7ebf8fdcad08106f6d56ab6': Duration: 00:03:20.91, start: 0.025057, bitrate: 128 kb/s Stream #0:0: Audio: mp3, 44100 Hz, stereo, s16p, 128 kb/s Metadata: encoder : LAME3.99r Output #0, mp3, to 'C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\transcoding-temp\87545491-7fd8-3588-da0d-17b0b1cecdfa.mp3': Metadata: TSSE : Lavf55.37.102 Stream #0:0: Audio: mp3 (libmp3lame), 44100 Hz, stereo, s16p, 128 kb/s Metadata: encoder : LAME3.99r Stream mapping: Stream #0:0 -> #0:0 (mp3 -> libmp3lame) Press [q] to stop, [?] for help size= 242kB time=00:00:15.41 bitrate= 128.4kbits/s size= 505kB time=00:00:32.28 bitrate= 128.2kbits/s size= 769kB time=00:00:49.18 bitrate= 128.1kbits/s size= 1038kB time=00:01:06.35 bitrate= 128.1kbits/s size= 1304kB time=00:01:23.41 bitrate= 128.1kbits/s size= 1571kB time=00:01:40.49 bitrate= 128.1kbits/s size= 1836kB time=00:01:57.44 bitrate= 128.1kbits/s size= 2091kB time=00:02:13.77 bitrate= 128.1kbits/s size= 2354kB time=00:02:30.59 bitrate= 128.0kbits/s size= 2617kB time=00:02:47.41 bitrate= 128.0kbits/s size= 2882kB time=00:03:04.39 bitrate= 128.0kbits/s [libmp3lame @ 036f1160] Trying to remove 1152 samples, but the queue is empty size= 3140kB time=00:03:20.90 bitrate= 128.0kbits/s video:0kB audio:3140kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.014370% does this make any sense to anybody?
Redshirt 1487 Posted June 6, 2014 Posted June 6, 2014 Does it work when your not playing channel content to the CC? Channels are new and I don't think we've done any testing streaming them to CC.
jimwhat 1 Posted June 6, 2014 Posted June 6, 2014 Had the same problem. Just follow these steps: The first couple of steps seem obvious, but just do them to make ensure that everything works 1. Go to your Chromecast App and make sure that your phone can see your Chromecast 2. Open the Media Browser (MB) Android app 3. Connect to your Media Server IP *Do not skip any of these next steps* 4. Click the Settings button on the top of the app 5. Under "Media Server" click on the name of your MB server. 6. Once you see the page that lists your MB Server and it says "connected", Press and Hold Down on the name of your MB Server. A box should pop-up that says "Edit" and "Delete". 7. Choose the Edit option. 8. On the next screen you'll see 2 fields that say "Internal Address and External Address". One of the should be blank. Copy your MB Server address into the blank field. Both the Internal and External fields should have the same Address. 9. Now hit OK to save your settings and restart the MB Android app (just to be safe). After that try playing a video and sending it to your Chromecast. It'll take a couple of seconds to buffer, but then it should work. Quality on my chromecast has been a bit iffy for some reason, but good luck
saajan4u 79 Posted June 7, 2014 Author Posted June 7, 2014 thats exactly hows its done. it doesnt do it for some reason.. still get the blue spinning wheel on tv (chromecast)
CBers 7554 Posted June 7, 2014 Posted June 7, 2014 @@jimwhat - I'm not sure your images are large enough 2
CBers 7554 Posted June 7, 2014 Posted June 7, 2014 cheers for that C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\ffmpeg\20140506\ffmpeg.exe -i "http://api.soundcloud.com/tracks/152659144/stream?client_id=78fd88dde7ebf8fdcad08106f6d56ab6" -threads 2 -vn -ab 128000 -ac 2 -id3v2_version 3 -write_id3v1 1 -y "C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\transcoding-temp\87545491-7fd8-3588-da0d-17b0b1cecdfa.mp3" does this make any sense to anybody? So it looks like you're trying to play an MP3 file that is on the internet ?? Input #0, mp3, from 'http://api.soundclou...08106f6d56ab6': If you click on that link, you get an error: This XML file does not appear to have any style information associated with it. The document tree is shown below. <error>401 - Unauthorized</error> Do you have local media that you can play back via the CC ??
jimwhat 1 Posted June 7, 2014 Posted June 7, 2014 @@jimwhat - I'm not sure your images are large enough Haha sorry about that. I guess it just used the native resolution from the phone. I'll try to fix it if I get a chance. 1
saajan4u 79 Posted June 8, 2014 Author Posted June 8, 2014 hi still have no luck even with local files.. any ideas where i'm going wrong.
CBers 7554 Posted June 8, 2014 Posted June 8, 2014 Can you post a link to the latest log from your Android device please. They are stored in: /sdcard/Mb3AndroidData/Logs Hopefully @@Redshirt can shed some light on the issue.
Redshirt 1487 Posted June 8, 2014 Posted June 8, 2014 If he's playing a soundcloud file, he's not doing it with the Android client. So either the server log isn't from an Android session, or the attempt is being made from the web browser. I can't help without the correct server/client logs.
saajan4u 79 Posted June 10, 2014 Author Posted June 10, 2014 i'll get a fresh log tonight.. I wasn't playing soundcloud tbh.. may have clicked once. my S4 Android phone doesn't have and SD card as a storage so where would I find the log for it.. sorry be a nuisance,
CBers 7554 Posted June 10, 2014 Posted June 10, 2014 i'll get a fresh log tonight.. I wasn't playing soundcloud tbh.. may have clicked once. my S4 Android phone doesn't have and SD card as a storage so where would I find the log for it.. sorry be a nuisance, It'll be on the phone storage. It'll still be /sdcard though. A real SD card would be mounted as /extSD.
Redshirt 1487 Posted June 10, 2014 Posted June 10, 2014 you may need to download a file manager to get them. Such as ES File Explorer. They'll be in sdcard\MB3AndroidData\Logs. I'd delete all the existing ones before you run your test again. Just to make sure you grab the right one.
saajan4u 79 Posted June 19, 2014 Author Posted June 19, 2014 well i think its something to do with my phones mb app cos it works like a charm from my nexus 7 tablet.. heres a freshly laid log.. i'd appreciate you time and help. thanks C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\ffmpeg\20140506\ffmpeg.exe -fflags genpts -i file:"C:\Box Sets\Terminator Quadrilogy\The Terminator 2\Terminator 2 Judgment Day.mp4" -map 0:0 -map 0:1 -map -0:s -vcodec wmv2 -force_key_frames expr:if(isnan(prev_forced_t),gte(t,.1),gte(t,prev_forced_t+5)) -vf "scale=min(iw\,1280):trunc(ow/dar/2)*2" -qmin 2 -maxrate 1799880 -bufsize 3599760 -r 23.97602 -vsync vfr -map_metadata -1 -threads 2 -acodec copy -y "C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\transcoding-temp\16564c47-7734-0f2a-6d72-75304b42d171.wmv"ffmpeg version N-62994-g2baf1c8 Copyright © 2000-2014 the FFmpeg developers built on May 5 2014 22:01:55 with gcc 4.8.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-decklink --enable-zlib libavutil 52. 81.100 / 52. 81.100 libavcodec 55. 60.103 / 55. 60.103 libavformat 55. 37.102 / 55. 37.102 libavdevice 55. 13.101 / 55. 13.101 libavfilter 4. 5.100 / 4. 5.100 libswscale 2. 6.100 / 2. 6.100 libswresample 0. 18.100 / 0. 18.100 libpostproc 52. 3.100 / 52. 3.100Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'file:C:\Box Sets\Terminator Quadrilogy\The Terminator 2\Terminator 2 Judgment Day.mp4': Metadata: major_brand : mp42 minor_version : 0 compatible_brands: mp42isomavc1 creation_time : 2010-09-05 06:28:48 encoder : HandBrake 0.9.4 2009112300 Duration: 02:36:08.64, start: 0.000000, bitrate: 2059 kb/s Stream #0:0(und): Video: h264 (Main) (avc1 / 0x31637661), yuv420p(tv, bt709), 1280x544, 1799 kb/s, 23.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc (default) Metadata: creation_time : 2010-09-05 06:28:48 encoder : JVT/AVC Coding Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, 5.1, fltp, 255 kb/s (default) Metadata: creation_time : 2010-09-05 06:28:48Output #0, asf, to 'C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\transcoding-temp\16564c47-7734-0f2a-6d72-75304b42d171.wmv': Metadata: WM/EncodingSettings: Lavf55.37.102 Stream #0:0: Video: wmv2 (WMV2 / 0x32564D57), yuv420p, 1280x544, q=2-31, 200 kb/s, 1k tbn, 23.98 tbc (default) Stream #0:1: Audio: aac ([255][0][0][0] / 0x00FF), 48000 Hz, 5.1, 255 kb/s (default)Stream mapping: Stream #0:0 -> #0:0 (h264 -> wmv2) Stream #0:1 -> #0:1 (copy)Press [q] to stop, [?] for helpframe= 112 fps=0.0 q=28.5 size= 438kB time=00:00:04.77 bitrate= 751.1kbits/s frame= 213 fps=207 q=31.0 size= 882kB time=00:00:09.04 bitrate= 798.7kbits/s frame= 293 fps=190 q=31.0 size= 1351kB time=00:00:12.28 bitrate= 900.4kbits/s frame= 418 fps=203 q=31.0 size= 1826kB time=00:00:17.57 bitrate= 850.8kbits/s frame= 556 fps=216 q=24.8 size= 2232kB time=00:00:23.23 bitrate= 787.0kbits/s frame= 685 fps=222 q=31.0 size= 2635kB time=00:00:28.67 bitrate= 752.9kbits/s frame= 783 fps=217 q=31.0 size= 3060kB time=00:00:32.76 bitrate= 765.0kbits/s frame= 849 fps=206 q=31.0 size= 3532kB time=00:00:35.49 bitrate= 815.0kbits/s frame= 910 fps=196 q=31.0 size= 3998kB time=00:00:38.05 bitrate= 860.4kbits/s frame= 969 fps=188 q=31.0 size= 4469kB time=00:00:40.44 bitrate= 905.2kbits/s frame= 1035 fps=183 q=31.0 size= 4963kB time=00:00:43.20 bitrate= 941.2kbits/s frame= 1111 fps=180 q=31.0 size= 5432kB time=00:00:46.44 bitrate= 958.1kbits/s frame= 1183 fps=177 q=31.0 size= 5935kB time=00:00:49.34 bitrate= 985.4kbits/s frame= 1287 fps=179 q=31.0 size= 6310kB time=00:00:53.76 bitrate= 961.5kbits/s frame= 1387 fps=180 q=31.0 size= 6710kB time=00:00:58.02 bitrate= 947.3kbits/s frame= 1479 fps=179 q=31.0 size= 7110kB time=00:01:01.78 bitrate= 942.8kbits/s frame= 1561 fps=178 q=31.0 size= 7426kB time=00:01:05.19 bitrate= 933.1kbits/s frame= 1650 fps=178 q=31.0 size= 7788kB time=00:01:08.94 bitrate= 925.3kbits/s frame= 1705 fps=174 q=31.0 size= 8235kB time=00:01:11.16 bitrate= 947.9kbits/s frame= 1747 fps=169 q=31.0 size= 8648kB time=00:01:12.87 bitrate= 972.1kbits/s frame= 1811 fps=167 q=31.0 size= 9116kB time=00:01:15.62 bitrate= 987.5kbits/s frame= 1881 fps=166 q=31.0 size= 9557kB time=00:01:18.50 bitrate= 997.2kbits/s frame= 1947 fps=164 q=31.0 size= 10019kB time=00:01:21.25 bitrate=1010.1kbits/s frame= 2015 fps=163 q=31.0 size= 10504kB time=00:01:24.13 bitrate=1022.7kbits/s frame= 2081 fps=161 q=31.0 size= 10932kB time=00:01:26.86 bitrate=1030.9kbits/s frame= 2151 fps=161 q=31.0 size= 11366kB time=00:01:29.79 bitrate=1037.0kbits/s frame= 2222 fps=160 q=31.0 size= 11829kB time=00:01:32.67 bitrate=1045.6kbits/s frame= 2293 fps=159 q=31.0 size= 12223kB time=00:01:35.63 bitrate=1046.9kbits/s frame= 2358 fps=158 q=31.0 size= 12729kB time=00:01:38.34 bitrate=1060.3kbits/s frame= 2406 fps=156 q=31.0 size= 13288kB time=00:01:40.35 bitrate=1084.7kbits/s frame= 2455 fps=154 q=31.0 size= 13676kB time=00:01:42.40 bitrate=1094.1kbits/s frame= 2525 fps=153 q=24.8 size= 14119kB time=00:01:45.31 bitrate=1098.3kbits/s frame= 2563 fps=151 q=31.0 size= 14457kB time=00:01:46.89 bitrate=1107.9kbits/s frame= 2599 fps=148 q=31.0 size= 14857kB time=00:01:48.40 bitrate=1122.8kbits/s frame= 2651 fps=147 q=31.0 size= 15216kB time=00:01:50.59 bitrate=1127.1kbits/s frame= 2701 fps=145 q=31.0 size= 15591kB time=00:01:52.65 bitrate=1133.8kbits/s frame= 2745 fps=144 q=31.0 size= 15976kB time=00:01:54.51 bitrate=1142.8kbits/s frame= 2787 fps=142 q=31.0 size= 16313kB time=00:01:56.24 bitrate=1149.7kbits/s frame= 2821 fps=140 q=31.0 size= 16619kB time=00:01:57.76 bitrate=1156.1kbits/s frame= 2862 fps=139 q=31.0 size= 17023kB time=00:01:59.46 bitrate=1167.3kbits/s frame= 2917 fps=138 q=31.0 size= 17432kB time=00:02:01.68 bitrate=1173.5kbits/s frame= 2955 fps=136 q=24.8 size= 17776kB time=00:02:03.24 bitrate=1181.5kbits/s frame= 2982 fps=134 q=24.8 size= 18094kB time=00:02:04.41 bitrate=1191.4kbits/s frame= 3013 fps=133 q=24.8 size= 18401kB time=00:02:05.78 bitrate=1198.4kbits/s frame= 3030 fps=130 q=24.8 size= 18582kB time=00:02:06.46 bitrate=1203.7kbits/s frame= 3046 fps=128 q=31.0 size= 18707kB time=00:02:07.14 bitrate=1205.3kbits/s frame= 3074 fps=127 q=31.0 size= 18963kB time=00:02:08.21 bitrate=1211.6kbits/s frame= 3119 fps=126 q=31.0 size= 19335kB time=00:02:10.21 bitrate=1216.4kbits/s frame= 3159 fps=125 q=31.0 size= 19723kB time=00:02:11.75 bitrate=1226.2kbits/s frame= 3197 fps=124 q=31.0 size= 20094kB time=00:02:13.46 bitrate=1233.4kbits/s frame= 3238 fps=123 q=31.0 size= 20454kB time=00:02:15.05 bitrate=1240.7kbits/s frame= 3289 fps=122 q=31.0 size= 20785kB time=00:02:17.21 bitrate=1240.9kbits/s frame= 3341 fps=122 q=31.0 size= 21129kB time=00:02:19.43 bitrate=1241.3kbits/s frame= 3387 fps=121 q=31.0 size= 21516kB time=00:02:21.31 bitrate=1247.3kbits/s frame= 3426 fps=121 q=31.0 size= 21891kB time=00:02:22.89 bitrate=1255.0kbits/s frame= 3462 fps=120 q=31.0 size= 22201kB time=00:02:24.39 bitrate=1259.5kbits/s frame= 3502 fps=119 q=31.0 size= 22569kB time=00:02:26.09 bitrate=1265.6kbits/s frame= 3542 fps=118 q=31.0 size= 22954kB time=00:02:27.79 bitrate=1272.3kbits/s frame= 3582 fps=117 q=31.0 size= 23285kB time=00:02:29.39 bitrate=1276.8kbits/s frame= 3619 fps=117 q=31.0 size= 23654kB time=00:02:30.94 bitrate=1283.8kbits/s
Redshirt 1487 Posted June 23, 2014 Posted June 23, 2014 The chrome cast is communicating with the server using the value in the internal address Field of your network connection. That address has to be valid and reachable by the device.
saajan4u 79 Posted June 24, 2014 Author Posted June 24, 2014 Spot on redshirt I was connecting using the external address duh.. Thank you everyone sorry to waste your time used tapatalk on me Samsung S4
CBers 7554 Posted August 8, 2014 Posted August 8, 2014 Anyone experiencing playback stopping whilst watching an MB3-based video on a Chromecast ? I'm having major issues, but no-one else is reporting it. Thanks.
