spacecowboy2050 0 Posted September 30, 2019 Posted September 30, 2019 I have set up my recordings folder to be : H:/ H:/Tv Shows H:/Movies The recordings all record in the right folder and the folder is in the library but shows as empty. I've even added these folders to an existing library but the recordings do not show. I've gone to my username and it shows I have access to all folders and libraries. What am I doing wrong?
ebr 16337 Posted September 30, 2019 Posted September 30, 2019 I have set up my recordings folder to be : H:/ H:/Tv Shows H:/Movies Exactly where did you set these values?
spacecowboy2050 0 Posted September 30, 2019 Author Posted September 30, 2019 In the DVR section of settings. I did mean to put \ not / though The shows do record in that folder but don't show up in recordings
ebr 16337 Posted September 30, 2019 Posted September 30, 2019 In exactly what fields did you put what values? Can you show me a screen shot? Thanks.
ebr 16337 Posted September 30, 2019 Posted September 30, 2019 We should probably wait for Luke to comment here but I'm suspecting a problem with the nested folder inclusion there (I know our example shows the same structure). I know if you setup a media library with those three exact folders it would create a problem. If you want to try something, try setting the default recording path to "H:\Unknown recordings"
spacecowboy2050 0 Posted September 30, 2019 Author Posted September 30, 2019 Thanks, will give it a go!
