tara.b 2 Posted September 30, 2019 Posted September 30, 2019 I have a user configured with PG/TV-PG Parental Controls, including all “Block items with no or unrecognized rating information”. Most parental controls appear to be working properly. However, some movies with custom parental ratings (e.g. Ghostbusters has an original rating of PG and I’ve set a custom rating of PG-13) are visible and playable. I’ve rescanned the media library several times and double checked the ratings. I’m not sure what’s different about these titles than other ones (e.g. Indiana Jones and the Temple of Doom was also originally PG, and I’ve set a custom rating of PG-13) which are working as expected. Any help figuring out what’s different between these custom ratings is appreciated. I’m running Emby server version 4.2.1.0. I’ve noticed this on both the Roku and iOS app.
tara.b 2 Posted September 30, 2019 Author Posted September 30, 2019 They show up under Movies, Latest, and Search. Basically, everywhere they shouldn’t.
Luke 42217 Posted September 30, 2019 Posted September 30, 2019 @@Happy2Play are you able to reproduce this?
ebr 16313 Posted September 30, 2019 Posted September 30, 2019 Hi. Can we please see the details for one of the ones you think isn't working properly? Thanks.
Happy2Play 9806 Posted September 30, 2019 Posted September 30, 2019 @@Happy2Play are you able to reproduce this? No any item I apply a higher custom rating on is restricted be the Maximum allowed parental rating.
Luke 42217 Posted October 1, 2019 Posted October 1, 2019 @@tara.b, how did you set the custom rating?
ebr 16313 Posted October 1, 2019 Posted October 1, 2019 By any chance did you also setup "Allow items with tag" and then these items have that tag...?
tara.b 2 Posted October 2, 2019 Author Posted October 2, 2019 Let me know how best to share the details... The parental controls are set as follows: The movies (both the ones that are working properly and the ones that are not) have custom ratings set as:
tara.b 2 Posted October 2, 2019 Author Posted October 2, 2019 I think I found the root cause... the custom parental ratings are not being updated in the nfo for all versions. In the kids account with parental controls set, Ghosbusters shows up but Indiana Jones does not: However, I noticed that the album art for Ghosbusters is showing the DVD cover on the kids account, but the BR cover shows on the main. The movie has a 1080p and 480p version, residing in the same folder. The 480p nfo file isn't updating with the custom rating. I edited the file manually, rescanned the library, and now the parental controls are working appropriately. So, there's a workaround, but for some reason the custom controls aren't being applied to all versions. 1
Happy2Play 9806 Posted October 2, 2019 Posted October 2, 2019 Yes when you are referring to multi-version, the UI only edits one version (the one being displayed).
tara.b 2 Posted October 2, 2019 Author Posted October 2, 2019 Oh! I guess it's working as intended then, just not as I expected. Note to self: edit metadata for all versions next time. Thanks!
ebr 16313 Posted October 2, 2019 Posted October 2, 2019 So these are actual multi-version movies meaning that only one item ever shows in the library and then there is the opportunity to select the version? If so, this is not working as intended...
