FrostByte 5453 Posted September 30, 2019 Posted September 30, 2019 (edited) Posting this for @@memc who provided information Problem: When using any of the Dark or Light themes the posters have no active border when selecting and the circle for posters with item counts are also missing the color highlight so they are hard to read. Problem does not occur when using other themes like Blue Radiance Problem was not there when using v1.0.64. All themes worked fine in 1.0.64 and can be verified when switching back and forth between versions TV JS8000 2015 App 1.0.67 Server 4210 Pic #1 using Blue Radiance, Movies library is highlighted Pic #2 using the Dark theme, No green highlight is seen with the active folder. Pic #3 using the Dark theme. Notice the green background in the circle is missing so you can't read the numbers very well. The background of the circle appears to be transparent on all posters and is hard to read This is using the Blue Radiance theme. The numbers are now readable and have a green background. Again this happens with all Dark and Light themes and was not there in version 1.0.64 Just a note I'm not seeing this problem with my 2018 Samsung, so this may be an issue with older TVs only. Maybe someone else can confirm Edited September 30, 2019 by FrostByte 1
EmbyHomeUser 3 Posted September 30, 2019 Posted September 30, 2019 Can confirm. I was checking for a solution when I found your post. Other themes work fine, the default one does not, making near impossible to navigate. TV: Samsung JU6000 series 1
FrostByte 5453 Posted September 30, 2019 Author Posted September 30, 2019 Thanks, sounds like it's 2015 TVs only so far
SamES 1084 Posted October 1, 2019 Posted October 1, 2019 I'm seeing the same problem with Dark Theme on 2017 QLED, so not just 2015 models 1
FrostByte 5453 Posted October 1, 2019 Author Posted October 1, 2019 I'm seeing the same problem with Dark Theme on 2017 QLED, so not just 2015 models Cool, maybe everything below Tizen 4.0 (2018) then? I'm definitely not seeing the issue. Maybe more people will chime in
Solution Luke 42242 Posted October 3, 2019 Solution Posted October 3, 2019 I posted a 1.0.68 usb update to resolve this. Thanks guys. 2
