Solution Luke 42255 Posted October 31, 2019 Solution Posted October 31, 2019 It should be: C:\Users\username\AppData\Roaming\Emby-Server\programdata\plugins\configurations\trakt.xml Try shutting down the server and then deleting that file. Then start back up and reconfigure trakt.
Guest benderisall Posted November 1, 2019 Posted November 1, 2019 Thanks, that worked. Before i deleted the file and restarted, this time I shut it down, deleted file and then started it again. Everything is working. Appreciate it.
piecesofme 3 Posted November 12, 2019 Posted November 12, 2019 (edited) FWIW, I’m having the exact same issue with Trakt. I’ve gone through the setup process with PIN, etc but it’s not actually exchanging any data. Only tried setting up one user and won’t be adding any more. I’ll try the delete thing shortly and see if that works to start over. Just wanted to report that whatever is going on with this is still happening. EDIT: It is now showing up in Trakt under my connections but it’s not actually bringing any data in despite the fact that I manually ran the Pull From Trakt job and it completed correctly without any trouble. Edited November 12, 2019 by piecesofme
Luke 42255 Posted November 27, 2019 Posted November 27, 2019 FWIW, I’m having the exact same issue with Trakt. I’ve gone through the setup process with PIN, etc but it’s not actually exchanging any data. Only tried setting up one user and won’t be adding any more. I’ll try the delete thing shortly and see if that works to start over. Just wanted to report that whatever is going on with this is still happening. EDIT: It is now showing up in Trakt under my connections but it’s not actually bringing any data in despite the fact that I manually ran the Pull From Trakt job and it completed correctly without any trouble. @@piecesofme, have you explored running the trakt scheduled tasks to import data into Emby?
piecesofme 3 Posted December 7, 2019 Posted December 7, 2019 @@Luke, yes, I did do that and still couldn’t get it to work. I’m not sure now what the issue was but I keep plugging away working on it trying to get the pin from Trakt to work and make the connection. Eventually, it finally worked. :shrug: I’m not going to argue with success - though I couldn’t share what actually ended up making it work in the end! I’m just happy that it did. Thanks so much for checking in on that. I really appreciate it. Sorry I’ve not been around more lately to respond, I have been really ill.
Przemek 70 Posted June 24, 2020 Posted June 24, 2020 On 12/7/2019 at 8:08 PM, Luke said: Thanks for the feedback. Hi, do You know where to find trakt.xml on linux server?
Luke 42255 Posted July 2, 2020 Posted July 2, 2020 On 6/24/2020 at 2:45 PM, Przemek said: Hi, do You know where to find trakt.xml on linux server? The top of your server log will contain the server's program data folder path. So start there, then: plugins\configurations\trakt.xml
Heval 4 Posted November 30, 2020 Posted November 30, 2020 I have the same issue, failed to sync trakt. Where can I find the trakt xml config file on Synology? Thanks!
Luke 42255 Posted December 1, 2020 Posted December 1, 2020 16 hours ago, Heval said: I have the same issue, failed to sync trakt. Where can I find the trakt xml config file on Synology? Thanks! Hi, the emby server log will show the path to the server's data folder, and then from there you go down to plugins\configurations\trakt.xml 1
Heval 4 Posted December 1, 2020 Posted December 1, 2020 17 minutes ago, Luke said: Hi, the emby server log will show the path to the server's data folder, and then from there you go down to plugins\configurations\trakt.xml Thank you, I was looking in the wrong emby folders.. Deleting the trakt.xml file works for me too. 1. stop emby. 2.delete trakt.xml. 3. restart machine. 4.get pin again.
