lifespeed 42 Posted September 29, 2019 Posted September 29, 2019 I have an Emby server running as a service on the same machine that I use as a v3.0.9 client to the v4.2.1.0 server. Recently I noticed the server is transcoding to the client *on the same machine*! When I configure the client to a particular server, I always delete the auto-detected server and put in "localhost" for the server, so it should not stream over the network. This has worked in the past, but now the auto-detect streaming bandwidth is setting the client to 6Mbps and transcoding DTS-HD to AC3. For comparison, I checked a client PC on a different physical machine on the same network, and it direct-plays from the same server over the local network. Please advise, logs attached. ffmpeg-transcode-32133e78-f099-4dd7-8f6b-b4d41964c3d8_1.txt ffmpeg-transcode-d49298c1-0e59-4163-98e6-54483ef2c201_1.txt theater-63705286198.txt embyserver.txt
Guest asrequested Posted September 29, 2019 Posted September 29, 2019 Is the media on the same machine, too?
Happy2Play 9806 Posted September 29, 2019 Posted September 29, 2019 it would appear there is a 7Mbps limit set somewhere. TranscodeReasons=ContainerBitrateExceedsLimit 2019-09-28 16:50:09.060 Info App: Bitrate exceeds DirectStream limit: media bitrate: 34000729, max bitrate: 7000000
Happy2Play 9806 Posted September 29, 2019 Posted September 29, 2019 (edited) Actually have you modified your network settings in Dashboard-Advanced? Would appear your serverip is considered Remote. 2019-09-28 16:50:09.060 Info App: RemoteClientBitrateLimit: 20000000, RemoteIp: 10.18.xx.x, IsInLocalNetwork: False Edited September 29, 2019 by Happy2Play
Luke 42217 Posted September 29, 2019 Posted September 29, 2019 Actually have you modified your network settings in Dashboard-Advanced? Yes this is probably the answer.
lifespeed 42 Posted September 29, 2019 Author Posted September 29, 2019 Is the media on the same machine, too? Yes, local RAID array.
lifespeed 42 Posted September 30, 2019 Author Posted September 30, 2019 Thank you for the responses. I have confirmed that when I activate a VPN to the internet the bandwidth limit is triggered. When the VPN is disabled the local client direct plays from the server on the same PC. I'm not sure where the 7Mbps is entered into the web interface, I have the internet maximum bitrate set to 20Mbps. So I will look at my outside domain name, which I have been trying to get working with port 8920 security. It would appear somehow the VPN is interfering with what should be a local route, "localhost".
Luke 42217 Posted September 30, 2019 Posted September 30, 2019 It would appear somehow the VPN is interfering with what should be a local route, "localhost". Yes that sounds right.
