flatliner 1 Posted December 20, 2019 Posted December 20, 2019 I've just had the same problem on my Nimbustor 4. To resolve, please follow these steps in the NAS ADM UI: - Stop the Emby application *** Ensure the user home folders are visible: - Launch Access Control - Go to Shared Folders - Select User Homes - Click Edit - Ensure "Disable file access to this shared folder" is not enabled (i.e. unchecked) - Click OK *** Create the emby user folder - Launch File Explorer - Go to User Homes - Create "emby" folder - Start the Emby application Emby should now launch. Hope that helps. 1
jjpold 0 Posted December 20, 2019 Author Posted December 20, 2019 I've just had the same problem on my Nimbustor 4. To resolve, please follow these steps in the NAS ADM UI: - Stop the Emby application *** Ensure the user home folders are visible: - Launch Access Control - Go to Shared Folders - Select User Homes - Click Edit - Ensure "Disable file access to this shared folder" is not enabled (i.e. unchecked) - Click OK *** Create the emby user folder - Launch File Explorer - Go to User Homes - Create "emby" folder - Start the Emby application Emby should now launch. Hope that helps. Nice try but in my case, it doesn't change a thing ! Emby's server app is installed but impossible to launch. I created "emby" folder but still nothing in it and anywhere on my NAS !
jjpold 0 Posted December 20, 2019 Author Posted December 20, 2019 I apologize for your issue. We're happy to continue helping you. We're just not sure yet what the issue is. Few weeks later... still not sure yet what the issue is ?
Luke 42237 Posted December 24, 2019 Posted December 24, 2019 same problem with beta 4.4.0.3 Hi, you haven't stated what your problem is
MyEmby2020 0 Posted January 22, 2020 Posted January 22, 2020 need help asustor as5304T can not connect to Emby Server 192.168.0.93 refused to connect.
Luke 42237 Posted January 22, 2020 Posted January 22, 2020 Hi, are you sure your emby server is running?
Maharaja 0 Posted January 22, 2020 Posted January 22, 2020 How can I check of the emby server is running
Maharaja 0 Posted January 22, 2020 Posted January 22, 2020 asustor as5304T can not connect to Emby Server 192.168.0.93 refused to connect Need help
Luke 42237 Posted January 23, 2020 Posted January 23, 2020 Have you tried rebooting the Nas and then starting emby server?
Maharaja 0 Posted January 24, 2020 Posted January 24, 2020 My emby server still not working but My plex is working fine Why is this Please help
jjpold 0 Posted January 24, 2020 Author Posted January 24, 2020 My emby server still not working but My plex is working fine Why is this Please help Same same ! and for weeks ! Not sure you will find help here !
jjpold 0 Posted January 26, 2020 Author Posted January 26, 2020 I have tried it, it doesn't work. The 4.4.0.9 beta version till can't install any emby server on my Asustor...
jorr@entofga.com 5 Posted May 3, 2020 Posted May 3, 2020 I have the same problem. I have spent 5 days and 10 hours trying to fix. Ever since I updated to the laster ADM 3.5beta version, the emby server will not start and says it cannot connect to the network. I have no proxy server set up and all ports are open. I even tried to factory reset my AS5304T but it would not let me install the pre-beta ADM and booted up with the beta still in place. Please help. I bought emby so I could stream video that PLEX could not.
Luke 42237 Posted May 9, 2020 Posted May 9, 2020 I have the same problem. I have spent 5 days and 10 hours trying to fix. Ever since I updated to the laster ADM 3.5beta version, the emby server will not start and says it cannot connect to the network. I have no proxy server set up and all ports are open. I even tried to factory reset my AS5304T but it would not let me install the pre-beta ADM and booted up with the beta still in place. Please help. I bought emby so I could stream video that PLEX could not. We'll have to take a look at the beta ADM. Thanks for letting us know.
jorr@entofga.com 5 Posted May 9, 2020 Posted May 9, 2020 Thank you. I have removed and then reinstalled an add-on 4GB memory card (it was not the problem) on my ASUSTOR and checked all 4 of my 8GB HDs for errors. None. I even reset my network router back to factory settings, reset my windows network settings, uninstalled and reinstalled the pre-beta and beta emby server program and it still cannot start and therefore never shows up on my external devices. I can connect to the NAS remotely, but emby will not run remotely or directly using the ASUSTOR Portal (connected directly to my TV via HDMI cable). We really need your help on this one.
corgao2001 0 Posted July 1, 2020 Posted July 1, 2020 1.- Delete the app first. 2.- After you please run the following via SSH (you may need to be root). groupdel emby userdel emby 3.- Install Emby. https://emby.media/community/index.php?/topic/74336-no-access-to-emby-server-interface/&do=findComment&comment=752638
pontch 0 Posted August 9, 2020 Posted August 9, 2020 Hey Guys, I have a problem with my Asustor 6302T and the emby server app. For several days I cannot connect to Emby server with my Browser or Windows Client app. Also i have no connection locally to Server I have already reinstalled the application, tried the beta version and deleted the Emby directory via the ssh connection, but unfortunately nothing helped.
Luke 42237 Posted August 9, 2020 Posted August 9, 2020 3 minutes ago, pontch said: Hey Guys, I have a problem with my Asustor 6302T and the emby server app. For several days I cannot connect to Emby server with my Browser or Windows Client app. Also i have no connection locally to Server I have already reinstalled the application, tried the beta version and deleted the Emby directory via the ssh connection, but unfortunately nothing helped. What package did you install?
pontch 0 Posted August 9, 2020 Posted August 9, 2020 (edited) emby-server-asustor_4.5.0.16_x86-64 and 4.4.3.0 both are do not work for me I disconnected both hard drives and reset the settings, restarted the system, installed the app from the store and it worked! Edited August 9, 2020 by pontch mistake fix
