lightsout 156 Posted September 30, 2019 Posted September 30, 2019 Surely a 1070ti can transcode one 4k file? My 1050ti center do it. Not sure why the lag but if these files are HDR it's pointless because the color will be wrong.
SirrSterl 0 Posted September 30, 2019 Author Posted September 30, 2019 Yes based on the log in the first post, if you want to be able to transcode this file on the fly, you may need a more powerful server machine. Can you describe the machine that emby server is running on? You could also check out our media conversion feature: https://emby.media/community/index.php?/blog/1/entry-423-emby-server-34-released/ This will allow you to convert the media ahead of time to a lower resolution. It’s my desktop PC. I7-2600 with a 1070ti. I guess I’ll just have emby convert them for me
SirrSterl 0 Posted September 30, 2019 Author Posted September 30, 2019 Surely a 1070ti can transcode one 4k file? My 1050ti center do it. Not sure why the lag but if these files are HDR it's pointless because the color will be wrong. That’s what I thought but I guess my processor can’t keep up? Honestly not sure.
lightsout 156 Posted September 30, 2019 Posted September 30, 2019 That’s what I thought but I guess my processor can’t keep up? Honestly not sure. I am not sure what's going on, I am not able to read the logs. But your setup should be fine. I am testing right now, sure I have more cores (Ryzen 1800x) but my cpu is at about 5-10%. I am transcoding a 4k file to 1080p 4mbps, the 1050ti has peaked at 45c. I used to do this with an i5-4570s as well. Your setup should be fine for one transcode of a 4k source. Something else seems off.
SirrSterl 0 Posted October 1, 2019 Author Posted October 1, 2019 I am not sure what's going on, I am not able to read the logs. But your setup should be fine. I am testing right now, sure I have more cores (Ryzen 1800x) but my cpu is at about 5-10%. I am transcoding a 4k file to 1080p 4mbps, the 1050ti has peaked at 45c. I used to do this with an i5-4570s as well. Your setup should be fine for one transcode of a 4k source. Something else seems off. Honestly playback has gotten worse for me since I upgraded to premium. I can only imagine my setup is fine but something in my settings is off
lightsout 156 Posted October 1, 2019 Posted October 1, 2019 (edited) Honestly playback has gotten worse for me since I upgraded to premium. I can only imagine my setup is fine but something in my settings is off That’s strange. There’s not all that much to setup. Do you have everything checked off in the transcoding section? I wonder if your network is actually the issue? Just thinking out loud. When you play a file that is transcoding and go to the server dashboard how is the performance? Is the transcoding able to keep up? Edited October 1, 2019 by lightsout
Bill4sman 10 Posted October 1, 2019 Posted October 1, 2019 How's your system when its directl playing?
SirrSterl 0 Posted October 3, 2019 Author Posted October 3, 2019 That’s strange. There’s not all that much to setup. Do you have everything checked off in the transcoding section? I wonder if your network is actually the issue? Just thinking out loud. When you play a file that is transcoding and go to the server dashboard how is the performance? Is the transcoding able to keep up? I have 200/20 currently direct to the server. Stuttering has definitely gotten worse on all videos regardless of size/4K/HDR so i turned off hardware acceleration for now. At least with it off I only have issues with those movies. Since nobody else seems to have these issues I'm thinking I'm going to just wipe it and set up a new server on a different computer and hope for the best
Sammy 791 Posted October 3, 2019 Posted October 3, 2019 I have 200/20 currently direct to the server. Stuttering has definitely gotten worse on all videos regardless of size/4K/HDR so i turned off hardware acceleration for now. At least with it off I only have issues with those movies. Since nobody else seems to have these issues I'm thinking I'm going to just wipe it and set up a new server on a different computer and hope for the bestWait a minute! What does your internet connection speed have to do with this? Did I miss something? This isn't a local client? Sent from my SM-G960U1 using Tapatalk
SirrSterl 0 Posted October 3, 2019 Author Posted October 3, 2019 Wait a minute! What does your internet connection speed have to do with this? Did I miss something? This isn't a local client? Sent from my SM-G960U1 using Tapatalk The log is from a local client but the issue is the same regardless of local or remote. Just sharing everything to show I'm at a loss
ebr 16313 Posted October 3, 2019 Posted October 3, 2019 The log is from a local client but the issue is the same regardless of local or remote. Just sharing everything to show I'm at a loss From a remote perspective, you will have a hard time stuffing a 50mb file through a 20Mb (advertised) upload pipe...
lightsout 156 Posted October 3, 2019 Posted October 3, 2019 Yeah I would ignore remote and get local sorted out first.
SirrSterl 0 Posted October 3, 2019 Author Posted October 3, 2019 From a remote perspective, you will have a hard time stuffing a 50mb file through a 20Mb (advertised) upload pipe... Yeah I know it’s closer to 14 when I ran the test but still never really had issues unless it was a large file. Not sure why I have issues with my 1070ti even on local but I’m upgrading to att gigabit and I’ll be upgrading my PC soon enough so it’s just going to have to be an issue I deal with for now. According to most people in this thread it should work fine but it doesn’t so I have to assume it’s my hardware
lightsout 156 Posted October 3, 2019 Posted October 3, 2019 Yeah I know it’s closer to 14 when I ran the test but still never really had issues unless it was a large file. Not sure why I have issues with my 1070ti even on local but I’m upgrading to att gigabit and I’ll be upgrading my PC soon enough so it’s just going to have to be an issue I deal with for now. According to most people in this thread it should work fine but it doesn’t so I have to assume it’s my hardware For sure your hardware is up to snuff, if we are talking local there is either an issue with your software setup/network/or client you are serving media to. Have you tried playing these same files through the web browser on the server itself. Or through some other device. You may just be throwing money away buying new hardware.
Happy2Play 9806 Posted October 3, 2019 Posted October 3, 2019 (edited) Sorry we would need to see ffmpeg logs of the issue when using HWA. As the only log posted is for the i7-2600 software decode/encode of hevc to h264. The i7-2600 appears to chocks on hevc conversion. Edited October 3, 2019 by Happy2Play
SirrSterl 0 Posted October 3, 2019 Author Posted October 3, 2019 For sure your hardware is up to snuff, if we are talking local there is either an issue with your software setup/network/or client you are serving media to. Have you tried playing these same files through the web browser on the server itself. Or through some other device. You may just be throwing money away buying new hardware. Yes they play fine on the web browser, just not anywhere else. Tried local on mobile, fire stick, roll. Roe more on iPad, and mobile. Always the same. Used to only have stuttering when playing large 4K files, after upgrading to premium I had the stuttering constantly regardless of file type. I’ve turned off GPU acceleration for now
SirrSterl 0 Posted October 3, 2019 Author Posted October 3, 2019 Sorry we would need to see ffmpeg logs of the issue when using HWA. As the only log posted is for the i7-2600 software decode/encode of hevc to h264. The i7-2600 appears to chocks on hevc conversion.Can you explain that in simpler terms?
Luke 42217 Posted October 4, 2019 Posted October 4, 2019 He's just making an educated guess but if you can provide the transcoding log then we can provide more detail. Thanks. 1
Sammy 791 Posted October 4, 2019 Posted October 4, 2019 (edited) Can you explain that in simpler terms? The CPU is choking on h.265 as expected. Additionally, it is possible your GPU isn't doing the work. Sent from my SM-G960U1 using Tapatalk Edited October 4, 2019 by Sammy
