crusher11 1153 Posted October 7, 2019 Author Posted October 7, 2019 The release notes only mention the season count. Is shuffling fixed as well?
Luke 42287 Posted October 7, 2019 Posted October 7, 2019 Please try it and report your experience. Thanks.
crusher11 1153 Posted October 17, 2019 Author Posted October 17, 2019 I'm having another issue - season posters aren't working on one of my drives. Working fine on the other drive. Seems to only apply to newly added ones.
Luke 42287 Posted October 17, 2019 Posted October 17, 2019 I'm having another issue - season posters aren't working on one of my drives. Working fine on the other drive. Seems to only apply to newly added ones. Why do you feel they're not working?
crusher11 1153 Posted October 17, 2019 Author Posted October 17, 2019 Because they're not working. It's just using the series poster instead.
crusher11 1153 Posted October 18, 2019 Author Posted October 18, 2019 It means it's just using the series poster instead of the season poster. I literally just said that.
ebr 16354 Posted October 18, 2019 Posted October 18, 2019 Hi. Exactly where and in what context? Please remember we are blind and cannot see whatever you are seeing. Screen shots are very helpful. Thanks. How to Report a Problem
speechles 2062 Posted October 18, 2019 Posted October 18, 2019 Also always remember the sources for these images and metadata also may go down, have quotas, etc... These services Emby depends on can have problems at any moment that are out of Emby's control. You may have simply ingested too much in a period of time and ran over the quota. Emby keeps track of when this happens and will stop fetching images. Once the interval of time has elapsed that determines how much data you can ingest you can again ingest more data and get more images. Since so many people depend on these services they must throttle/quota users to keep sanity on their bandwidth.
crusher11 1153 Posted October 18, 2019 Author Posted October 18, 2019 Hi. Exactly where and in what context? Please remember we are blind and cannot see whatever you are seeing. Screen shots are very helpful. Thanks. How to Report a Problem It acts exactly as it would if the season poster wasn't there at all.
Luke 42287 Posted October 18, 2019 Posted October 18, 2019 We're doing our best to help you but if all you're going to provide is about two words then that is going to be very difficult. As you can see there isn't any general problem with tv images or there would be a mass uprising in the community. Based on current information all I can tell you is compare your file naming to our supported naming conventions: https://github.com/MediaBrowser/Wiki/wiki/TV-naming
crusher11 1153 Posted October 19, 2019 Author Posted October 19, 2019 As I said, it seems to only affect one drive in my multi drive series, which is why I posted about it in this thread rather than making a new one. It was working fine previously so it may be related to the fix that was put in for shuffling and the season count.
Luke 42287 Posted October 19, 2019 Posted October 19, 2019 No, I see no problem related to TV images.
Happy2Play 9814 Posted October 20, 2019 Posted October 20, 2019 (edited) How about a specific example so I can attempt to reproduce. I do see something changed since season 3 & 4 are not showing season images like when I posted in post 21. The season images are not in the series folder on that drive. But when I refreshed missing, they were re-added. Edited October 20, 2019 by Happy2Play
crusher11 1153 Posted October 20, 2019 Author Posted October 20, 2019 That's basically what I see, yeah. Season posters on one drive work fine, but not on the others. I tried scanning and it didn't help. I'm not at my server at the moment so I can't provide any further info until later on.
crusher11 1153 Posted October 21, 2019 Author Posted October 21, 2019 (edited) Okay, so: 1. All the season posters I had in place before moving to the beta are still there. Some on my local drive, some on network drive 1, some for seasons with episodes on both drives. 2. Posters on network drive 1 for seasons on network drive 1 work. 3. Posters on the local drive for seasons spread across the local drive and network drive 2 do not work. 4. Posters on the local drive for seasons spread across the local drive and network drive 1 don't work either. 5. Posters on network drive 1 for seasons spread across network drive 1 and network drive 2 also don't work. So it seems if episodes in the season are spread across multiple drives, the poster doesn't display, but this only applies to posters added after I moved to the beta. Edited October 21, 2019 by crusher11
Luke 42287 Posted October 21, 2019 Posted October 21, 2019 can you show a screenshot to demonstrate? Thanks.
crusher11 1153 Posted October 21, 2019 Author Posted October 21, 2019 Here. 1992, 1993, 1994, and 1995 have no poster.
Happy2Play 9814 Posted October 21, 2019 Posted October 21, 2019 And if you reapplied a season image that is missing where does the server place the image? You will probably have to monitor the log when you do this if not all the perspective drives.
crusher11 1153 Posted October 21, 2019 Author Posted October 21, 2019 I haven't been applying them through the UI, just placing a "poster.jpg" in the season's folder.
