Squee 5 Posted September 22, 2019 Posted September 22, 2019 Hi all, I am very new to Emby and still in the process of figuring out all the different possibilities. I have one question regarding the in-app quality settings. Can I somehow have different quality settings when I am on the road and have a WiFi connection and lower quality settings when on cellular data? So far I only found the „internet quality settings“ - but this doesn’t seem to differentiate between WiFi and cellular data. Have I overlooked something? Thank you very much for your help. Squee
Luke 42242 Posted September 29, 2019 Posted September 29, 2019 Hi, correct, that's currently the way it is. More settings are possible for the future. For now, best thing to do would be to change it when needed. Thanks.
Squee 5 Posted September 29, 2019 Author Posted September 29, 2019 Hi Luke, thank you very much for your answer. So I guess I hope that this setting will soon make its way into a future update. Kind regards, Martin
