Nostromo86 17 Posted September 20, 2019 Posted September 20, 2019 (edited) Hi This is the first time I try to use Emby and it's great. congratulations.Here is my installation:a movie folder with inside folders for each movie with inside a strm containing youtube linkEmby server is okKodi with the theme embuary is okWhen I start a movie and I stop in the middle, it goes into watched ,I would like it to be continuously watching.Below is my log and a strm file for the example. Kodi log https://pastebin.com/TudVxa0G plugin://plugin.video.youtube/play/?video_id=ZqGqBUtxhNY 2019-09-20 18:44:46.441 T:6400 NOTICE: EMBY.hooks.player -> Runtime is missing, Kodi runtime: 5367 If i add this strm file localy in kodi thats works. i thinks the problem is server side. Thank you Edited September 20, 2019 by Nicestream
Luke 42237 Posted September 21, 2019 Posted September 21, 2019 Emby Server doesn't support this url: plugin://plugin.video.youtube/play/?video_id=ZqGqBUtxhNY That's why there is no runtime. Try using an strm file that points to an actual video file, and then I think this should work.
Angelblue05 4132 Posted September 21, 2019 Posted September 21, 2019 I think I can fix this by providing the runtime ticks to the server which is what I will do... I’ll get that fixed for the next build.
Nostromo86 17 Posted September 23, 2019 Author Posted September 23, 2019 I think I can fix this by providing the runtime ticks to the server which is what I will do... I’ll get that fixed for the next build. Alright Thank you
