daldana 126 Posted September 26, 2019 Posted September 26, 2019 Here are my logs after installing the version from Post #18. FYI, the Quicksync decoders each took about a minute to start a Live TV stream and the DX11VA decoder took about 3-5 seconds. ffmpeg-transcode-DX11VA Decoder.txt ffmpeg-transcode-QuickSync Intel(R) HD Graphics - D3D11 Decoder.txt ffmpeg-transcode-QuickSync Intel(R) HD Graphics Decoder.txt
softworkz 5130 Posted September 26, 2019 Posted September 26, 2019 @@daldana - Thanks a lot for trying! Could you do a quick check if it's working with the stable ffmpeg from post #22?
daldana 126 Posted September 26, 2019 Posted September 26, 2019 Ok, using the file from post #22, here are my logs attached. It's interesting that with this ffmpeg, using the Quicksync decoders with the Quicksync encoder (not the D3D version) produced very smooth playback. Also using the Quicksync Intel ® HD Graphics decoder with the Quicksync Intel ® HD Graphics - H.264 (AVC) was showing only 1.3% CPU in Windows Task Manager. ffmpeg-transcode-3ef77fb8-568c-4849-af03-8719a13d53c7_1.txt ffmpeg-transcode-539c3b91-652f-4d92-92a6-74c5ef196236_1.txt ffmpeg-transcode-a95d515f-2b89-42de-ab90-989829ebae09_1.txt
snitchy 3 Posted September 26, 2019 Author Posted September 26, 2019 @@softworkz Sorry for the delay in replying - I've tried the two commands that you posted but unfortunately I got the same error message as I always get. I did also try it for the older ffmpeg and the newer one you posted, but got the same results I'm afraid. Do appreciate your continued efforts though
Luke 42216 Posted November 8, 2019 Posted November 8, 2019 @@daldana @@snitchy If any of you would like to try the beta server that would be helpful as it has a newer ffmpeg build that might make a difference. Thanks.
softworkz 5130 Posted November 12, 2019 Posted November 12, 2019 @@daldana@@snitchy I'm quite confident that it will work for both of you now... Please retry if you got a chance to do so.
snitchy 3 Posted November 12, 2019 Author Posted November 12, 2019 Hello again, Firstly, really sorry for taking a while to get back to you, I've just had a really busy few weeks so haven't had a chance to test this out for you. I've just given it a ago now and I'm sorry to say it still reverted back to software encoding I've attached the logs so you can see, and I'll be happy to test anything else if you want me to change any of the settings. Just let me know. ffmpeg-transcode-f7066b04-d48e-48dc-9649-30bde30f8789_1.txt
softworkz 5130 Posted November 13, 2019 Posted November 13, 2019 @@snitchy - Thanks for the log Would you be able to run the following command line and see whether it works: P:\Emby\system\ffmpeg.exe -loglevel +timing -hwaccel qsv -hwaccel_device hw -qsv_device 0 -c:v h264_qsv -f matroska -i file:"\\walle\Movies\Ghostbusters (1984)\Ghostbusters (1984) Bluray-1080p.mkv" -threads 0 -map 0:0 -map 0:1 -sn -c:v:0 h264_qsv -b:v:0 1116000 -maxrate 1116000 -bufsize 2232000 -preset veryfast -profile:v:0 high -level:v:0 4.0 -g:v:0 72 -keyint_min:v:0 72 -sc_threshold:v:0 0 -copyts -vsync -1 -codec:a:0 ac3 -metadata:s:a:0 language=eng -disposition:a:0 default -ac:a:0 6 -ab:a:0 384000 -ar:a:0 48000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_write_temp 1 -segment_list_type m3u8 -segment_start_number 0 -segment_list "P:\Emby\programdata\transcoding-temp\fb08243efa127b38a03eb9ecbfb01e78.m3u8" -y "P:\Emby\programdata\transcoding-temp\fb08243efa127b38a03eb9ecbfb01e78%d.ts" Thanks.
softworkz 5130 Posted January 4, 2020 Posted January 4, 2020 @@snitchy @@daldana Today's beta (4.4.0.5) comes with a new ffmpeg version (2020-01-01) for Windows including some fixes for QuickSync. It would be great if you could try that new version and let us know about the results. Thanks, softworkz
vdatanet 1619 Posted January 4, 2020 Posted January 4, 2020 (edited) In beta 4.4.0.5 for Linux, transcoding does not work (not hardware, not software). I get this error: 08:42:59.600 Unrecognized option 'print_graphs_file'. 08:42:59.600 Error splitting the argument list: Option not found Examples: ffmpeg-transcode-2cd5d566-1abc-4987-9496-e9d6962b9d85_1.txt ffmpeg-transcode-fd77fa62-439e-4195-bb65-7b1f60d667a3_1.txt embyserver-63713724492.txt hardware_detection-63713724497.txt Edited January 4, 2020 by vdatanet
softworkz 5130 Posted January 4, 2020 Posted January 4, 2020 @@vdatanet - Thanks a lot for the quick feedback! A version check got lost but we've already fixed it. New packages are currently being built. This may take a while..
vdatanet 1619 Posted January 4, 2020 Posted January 4, 2020 @@vdatanet - Thanks a lot for the quick feedback! A version check got lost but we've already fixed it. New packages are currently being built. This may take a while.. Tested new build and transcoding is fixed. Thanks!
daldana 126 Posted January 6, 2020 Posted January 6, 2020 Attached are my logs, there are three sets one for each decoder option (all of the -1's go together, then the -2's, etc). The regular Quicksync HD decoder and the DX11VA decoder both worked great between 8% and 12% CPU for Live TV viewing. The D3D version took almost a full minute to start the video and once it did start, it's CPU usage was around 15%. embyserver-1.txt ffmpeg-transcode-92cb5dec-8a81-4bc9-ab38-974268f3a618_1-1.txt hardware_detection-63713829699-1.txt embyserver-63713829681-2.txt ffmpeg-transcode-bff3ea42-5b8f-46c2-8df2-169c8a819fd9_1-2.txt hardware_detection-63713829155-2.txt embyserver-63713829138-3.txt ffmpeg-transcode-fd5bebae-efc6-416d-8de8-de405bed6ba3_1-3.txt hardware_detection-63713828807-3.txt
softworkz 5130 Posted January 6, 2020 Posted January 6, 2020 @@daldana - Do you have a monitor connected to the onboard graphics of the machine on which you're running Emby server? Are you working on that machine directly or via remote desktop?
daldana 126 Posted January 6, 2020 Posted January 6, 2020 softworkz, I do have a monitor connected to the server, but I was working on it via remote desktop. The device I was using to view the video was an Android smart phone.
softworkz 5130 Posted January 7, 2020 Posted January 7, 2020 Just recently we had another case where a remote desktop connection had totally disabled all hw acceleration. You should read through this topic: https://emby.media/community/index.php?/topic/80319-question-about-quicksync-and-rdp/?p=821645 Please try one of the suggestions and let us know how it works out.
daldana 126 Posted January 11, 2020 Posted January 11, 2020 softworkz, I have both the stable server version and the beta version running on the same PC, so I'm curious as to why the stable version uses hardware acceleration but the beta version doesn't. I used a web browser to monitor the settings dashboard of both, not via remote desktop. I've attached the ffmpeg logs, the stable version is the 9:13pm and the beta version was at 9:11pm. Thanks for taking a look at the logs. Dave ffmpeg-transcode-0bd9714b-61a5-4a94-b1bc-62a55171a2fe_1.txt ffmpeg-transcode-b156f273-1aac-478f-97a8-fb490b4aaff0_1.txt
softworkz 5130 Posted January 11, 2020 Posted January 11, 2020 Thanks for the new logs, I'll need a while trying to replicate this. One question: Are you seeing the same behavior when you play recorded tv instead of live tv?
softworkz 5130 Posted January 11, 2020 Posted January 11, 2020 (edited) One question: Are you seeing the same behavior when you play recorded tv instead of live tv? And: Does it also fail when the decoder is H.264 instead of mpeg2? (I mean with a different video file) Edited January 11, 2020 by softworkz
daldana 126 Posted January 11, 2020 Posted January 11, 2020 Recorded TV behaves the same way on both servers, acceleration on stable but not on beta, but with an H.264 file I get acceleration on both servers. I've attached the ffmpeg file from the beta server.
daldana 126 Posted January 11, 2020 Posted January 11, 2020 Sorry, file attached now. ffmpeg-transcode-cd2968a4-f069-4d66-a590-8fcbf7f19e47_1.txt
softworkz 5130 Posted January 11, 2020 Posted January 11, 2020 (edited) Thanks, that's very good information, as that boils it down to be an issue with the QuickSync Mpeg2Decoder in the recent betas. Please hold on, I'll post here as soon as I got some news on the issue! Edited January 11, 2020 by softworkz
softworkz 5130 Posted January 27, 2020 Posted January 27, 2020 I'm glad too tell that this problem has been fixed and the fix will be included in the next beta Thanks for reporting!
Luke 42216 Posted January 28, 2020 Posted January 28, 2020 It's up in case you'd like to try it out. Thanks.
