dougaddams 1 Posted September 19, 2019 Posted September 19, 2019 Hey Guys! Is there anyway to add extra parameters to the FFMPEG CLI? I think it would be a good idea if possible to add an arguments box to the advanced trans-coding page so people may enter any extra parameters they wished to add to FFMPEG for streams. Just a thought if there is not a way to do it at the moment. I can't seem to see any way to add extra arguments myself without attempting to decompile and dig. Is this do able? does anyone know?
Luke 42246 Posted September 19, 2019 Posted September 19, 2019 Hi, can you give an example of what you'd like to customize? This is not as easy as it sounds because the location of any additions will usually make a difference. Thanks.
Sammy 791 Posted November 5, 2019 Posted November 5, 2019 Hi, can you give an example of what you'd like to customize? This is not as easy as it sounds because the location of any additions will usually make a difference. Thanks. And... NOTHING! Frustrating as hell!
Happy2Play 9814 Posted November 5, 2019 Posted November 5, 2019 And... NOTHING! Frustrating as hell! Well you could provide and example. 1
Sammy 791 Posted November 5, 2019 Posted November 5, 2019 (edited) Here is my example! Edited November 5, 2019 by Sammy
dougaddams 1 Posted November 6, 2019 Author Posted November 6, 2019 Oh my Gosh I am so sorry I genuinely forgot about this thread! Yes sure I am pretty much suggesting a box where we could add extra parameters to the FFMPEG argument. I 100% cant remember why I was requesting this however I have a feeling it would have been related to limiting or enforcing that my GPU too precedence over the CPU. I think my resolution was a quadro graphics card. 1
