craigtrombly 0 Posted June 5, 2014 Posted June 5, 2014 In this screenshot, it currently shows 1057 movies https://dl.dropboxusercontent.com/u/55833058/mb3-sc1.png https://dl.dropboxusercontent.com/u/55833058/Screenshot%202014-06-04%2017.17.26.png As you can see, I have 1212 movies in the Report section, but only have 1057 in the browse section Now, when I add more, it often changes to an unexpected number that almost seems random. The Movie "Up" is in the Search and not in the Browse alphabetically. https://dl.dropboxusercontent.com/u/55833058/mb3-sc2.png https://dl.dropboxusercontent.com/u/55833058/Screenshot%202014-06-04%2017.15.28.png Why would a movie not show in the browse section?
Solution Luke 42180 Posted June 5, 2014 Solution Posted June 5, 2014 Go into the user profile and check the display settings. There's a setting to group movies underneath their collections, so the collections are substituted in place. You can turn this off if you don't want it. Either way, the reports section doesn't do this, which is why you see the difference. 2
