pataphysician 0 Posted September 18, 2019 Posted September 18, 2019 (edited) I use nextpvr to record and then these are automatically copied to my emby tv or movie collection, nextpvr records as the native .ts from the broadcast. I have never had any problems playing them until the 4.0 series server, when I had a strange problem on recordings that were over an hour, exactly at 1 hour 11 minute point in playback, ffmpeg would crash, initially I thought there was something wrong with the recordings, as it was just one show. But I had recorded and played back the previous season of this show on the 3.7 server just fine, and now these old recordings had the exact same problem. They all played back fine on Emby for Kody, but on AndroidTV and FireTV they would crash, which seemed to probably be something in the remuxing, which happens on these devices with .ts files, but not on Emby for Kodi on my Linux machine. As a temporary fix I converted the new recordings to mpeg2 in a mkv, which doesn't get remuxed. I don't have transcoding turned on, because my server is pretty weak, and all devices are connected by wire, so streaming .ts files is my preference as it uses so little server resources, and electricity, and has given me flawless playback until now. Now that I have some time, I looked at the issue again, and with the latest server 4.2.1, ffmpeg no longer hard crashes, but gets killed and restarts with jittery scene and repeat of audio, again always at the 1 hour 11 minute mark on any .ts recording over an hour, these restarts will happen every minute or so until the end of the film. Attached is a log from when it happens where you can see ffmpeg get the q command which is a soft kill, it will then go on to create several new log files as it keeps happening, I can provide more files if necessary. ffmpeg-directstream-6aef15f5-27dd-469f-8995-d01b147a107b_1.txt Edited September 18, 2019 by pataphysician
Luke 42217 Posted September 18, 2019 Posted September 18, 2019 Hi there, if you turn transcoding back on, does it end up playing the same way, or does it transcode? This will tell us whether or not the app would have wanted to transcode it. Thanks.
pataphysician 0 Posted September 18, 2019 Author Posted September 18, 2019 If I turn on transcoding it still happens, and it is still just remuxing. Thanks
Luke 42217 Posted September 18, 2019 Posted September 18, 2019 Can you attach the log that it produces? thanks.
pataphysician 0 Posted September 20, 2019 Author Posted September 20, 2019 Here is the first log, playing the show and forwarding to 1 hour 10 minutes , then the log ends at the first stutter ffmpeg-directstream-9020e277-7590-4524-b941-c38582f274bc_1.txt Then there are a series of short new logs as it continues to stutter every minute or so ffmpeg-directstream-eb347f5c-bfb0-47c8-91da-0d6ce52a1044_1.txt ffmpeg-directstream-48dd20a4-aadf-4f69-a485-50c3a3eaf027_1.txt ffmpeg-directstream-d0c93399-66a5-44ba-a4fe-9388dd4f05ac_1.txt ffmpeg-directstream-ed92a89c-0914-469e-88fd-6869dc77ecdb_1.txt
Luke 42217 Posted October 14, 2019 Posted October 14, 2019 Hi @@pataphysician, are you still running into this?
pataphysician 0 Posted October 16, 2019 Author Posted October 16, 2019 Yeah, I'm still having that problem, did you have a chance to look at the logs I posted in that thread some weeks ago, were they any help?
Luke 42217 Posted October 17, 2019 Posted October 17, 2019 Would you mind submitting a log from the FireTv app so that @@ebr can review? Thanks.
pataphysician 0 Posted October 17, 2019 Author Posted October 17, 2019 I turned on debug features and then played one of the problem videos, PBS Country S1E1, fast forwarding to about 1:10 and then let it play, then used the send logs in the app just now, not sure how you will match that up with my user though.
ebr 16313 Posted October 18, 2019 Posted October 18, 2019 I turned on debug features and then played one of the problem videos, PBS Country S1E1, fast forwarding to about 1:10 and then let it play, then used the send logs in the app just now, not sure how you will match that up with my user though. Please tell me the name of the Emby user that was logged in at the time and the exact time you sent the log. Thanks.
pataphysician 0 Posted October 19, 2019 Author Posted October 19, 2019 Patrick was the Emby user logged in the time was about five minutes before I posted
ebr 16313 Posted October 22, 2019 Posted October 22, 2019 Can you describe what exactly happened when you let this item play after the FF? There is so much in the logs that I cannot see your seek event. There are a lot of discontinuity messages and the like that you can see sometimes in live streams. Can you test recording one of these exact same channels with Emby?
pataphysician 0 Posted October 22, 2019 Author Posted October 22, 2019 I did try to record with Emby with the same effect back when it first happened, I was thinking maybe its was due to NTFS data streams that nextpvr used for metadata, but no luck, they had the same problem. This is Emby on Windows 7, but since Windows 7 is going to be out of support in a few months, I decided this weekend to start the switch to Linux and use Emby PVR, so I setup a test system and decided to copy over some of the problem recorded ts files, to see if I would still have the problem, and they all play completely fine. So my guess is, this is either something specific to windows 7, or maybe there is something screwed up on my emby server which I've been using for three years, so either way it's probably not worth bothering with, thanks for all your help.
ebr 16313 Posted October 22, 2019 Posted October 22, 2019 Okay, let us know if you run into it again. Thanks.
ebr 16313 Posted October 26, 2019 Posted October 26, 2019 Okay, we have a user reporting the exact same thing with some AVI files. Also at exactly 1:11. That is too much of a coincidence for it to be a single file problem... https://emby.media/community/index.php?/topic/78688-freeze-au-bout-de-71-minutes/?p=800341
