Erik 124 Posted September 17, 2019 Posted September 17, 2019 Hi, On a New TCL Roku TV, using the internal speakers, when i play any media (TV Shows/Movie/Live TV) that is 2 channel (As verified by Stats for Nerds), then the volume is normal (as compared to just using an antenna without emby and also when using external HDMI sources). However, through Emby, when i play media (Again, tested Movies and Live TV) that is 5.1, the Stats for Nerds shows its streaming 5.1 but the volume is extremely low and I have to at least double the TV volume to get to the same loudness. Any idea's of why? or how I can fix this? Thanks, Erik
Luke 42242 Posted September 17, 2019 Posted September 17, 2019 Hi, this means it is direct playing the 5-channel source and the Roku is internally down-mixing. It sounds like the Roku video player may not be doing a great job of it.
ebr 16335 Posted September 17, 2019 Posted September 17, 2019 I would check the audio setting on the device itself and be sure it is set to stereo only.
speechles 2062 Posted September 17, 2019 Posted September 17, 2019 (edited) Hi, On a New TCL Roku TV, using the internal speakers, when i play any media (TV Shows/Movie/Live TV) that is 2 channel (As verified by Stats for Nerds), then the volume is normal (as compared to just using an antenna without emby and also when using external HDMI sources). However, through Emby, when i play media (Again, tested Movies and Live TV) that is 5.1, the Stats for Nerds shows its streaming 5.1 but the volume is extremely low and I have to at least double the TV volume to get to the same loudness. Any idea's of why? or how I can fix this? Thanks, Erik Play any video. While the video player is playing press the * button on your remote. Look for Volume Mode in the options menu that appears. Make sure Volume Mode is OFF. If it is LEVELING it will make loud sounds quiet and quiet sounds a little louder. It basically makes all audio the same sound level. If it is NIGHT it will make loud sounds quiet and quiet sounds just stay quiet. It basically makes all loud sounds quieter. When Volume Mode is not OFF it will only use stereo. It is decimate the audio. When you turn Volume Mode to OFF you allow the normal sound levels. Edited September 17, 2019 by speechles
Gilgamesh_48 1243 Posted September 17, 2019 Posted September 17, 2019 Play any video. While the video player is playing press the * button on your remote. Look for Volume Mode in the options menu that appears. Make sure Volume Mode is OFF. If it is LEVELING it will make loud sounds quiet and quiet sounds a little louder. It basically makes all audio the same sound level. If it is NIGHT it will make loud sounds quiet and quiet sounds just stay quiet. It basically makes all loud sounds quieter. When Volume Mode is not OFF it will only use stereo. It is decimate the audio. When you turn Volume Mode to OFF you allow the normal sound levels. Even though I did not ask the question and I do not have the problem described I want to thank you for posting this. Since the "modes" were introduced I tried to get Roku, on their help board, to explain exactly what the various modes did and how they were expected to work but the only answers I received were so convoluted and ambiguous and often contradicted each other that I basically was less informed after reading them than I was before. You just gave a simple, direct and understandable answer in just a few concise and direct sentences to the question that seems to be beyond Roku's ability to answer. I had made a guess based on observation and it was. at least mostly, correct but it is good to have confirmation. Once again, thank you very much. BTW: I use nothing but stereo audio so I keep the setting at "Leveling" so I can hear soft sounds and mostly avoid being blasted out of my chair on loud sections.
