rancid_ 1 Posted September 16, 2019 Posted September 16, 2019 Afternoon all, I am a complete newbie to IPTV, but spent the entire weekend trying providers, apps, setup emby and also NextPVR so I am progressing. The issue I am having is with Emby's implementation of NextPVR which has me completely baffled. I would like to use NextPVR to be my main guide for Live TV channel surfing since it gives you more flexibility for channel grouping, removing, etc. I originally setup my m3u and epg files in Emby, downloaded the NextPVR plugin (and configured it) along with adding the same files in NextPVR, but things began really slowing down which I believe is because it was polling the data twice. I removed the live tv m3u file and the the epg file and assumed Emby would utilize NextPVR for the guide as I wanted, but nothing is showing up. I did confirm that in NextPVR all the channels are there with the guide data. What is the easiest way to set this up assuming it can do what I am wanting? Thanks for the help!
arrbee99 1836 Posted September 17, 2019 Posted September 17, 2019 Few things might be worth mentioning - Think you need Emby Premiere to watch Live TV, even if its via Nextpvr. There's a v4 version of NextPVR and a new v5 version, the same applies to NextPVR Emby plugins, so make sure you're using v4 NPVR with v4 version of the plugin and the same for v5. After you removed the m3u and epg from Emby, try a few things like refreshing the guide, restarting Emby server etc. Check NextPVR server is still running.
rancid_ 1 Posted September 17, 2019 Author Posted September 17, 2019 (edited) Few things might be worth mentioning - Think you need Emby Premiere to watch Live TV, even if its via Nextpvr. There's a v4 version of NextPVR and a new v5 version, the same applies to NextPVR Emby plugins, so make sure you're using v4 NPVR with v4 version of the plugin and the same for v5. After you removed the m3u and epg from Emby, try a few things like refreshing the guide, restarting Emby server etc. Check NextPVR server is still running. Thanks, I have premiere emby and I restarted both servers several times with no luck. Is the correct procedure to not add any guide or playlists to emby and do everything through NextPVR? Edited September 17, 2019 by rancid_ 1
rikiwi 32 Posted September 17, 2019 Posted September 17, 2019 Thanks, I have premiere emby and I restarted both servers several times with no luck. Is the correct procedure to not add any guide or playlists to emby and do everything through NextPVR? Yes, that's what I do. Sent from my SM-G950F using Tapatalk
arrbee99 1836 Posted September 17, 2019 Posted September 17, 2019 That sounds correct. I'm using NextPVR (V5) at the mo, and don't have anything under Live TV - I guess under Plugins, you have something like - 8866 = standard NextPVR port thingy http... = same as that given as Server Dashboard > In-Home (LAN) access Think NextPVR server has something like a 'Allow Remote Access' box which I presume should be ticked.
rancid_ 1 Posted September 17, 2019 Author Posted September 17, 2019 (edited) Thanks all, I will give it another go and perhaps upgrade to v5. Edited September 17, 2019 by rancid_
arrbee99 1836 Posted September 17, 2019 Posted September 17, 2019 Wouldn't have thought moving to v5 would make much of a difference, but if you do, think the Emby v5 plugin is here - https://emby.media/community/index.php?/topic/74439-nextpvr-v5-emby-plugin/
rancid_ 1 Posted September 17, 2019 Author Posted September 17, 2019 (edited) Dumb question, where does the plugin go? I tried uninstalling the old one and placing this in the emby-server plugins directory but it isn't picking up the plugin. If I put it in the program data folder and delete the 3.3 plugin it shows 3.5, but is just constantly showing a spinning icon. Thx *update - doesn't work with beta emby, went back to official and it resolved the spinning icon issue.* Edited September 17, 2019 by rancid_
arrbee99 1836 Posted September 17, 2019 Posted September 17, 2019 Far as I remember you uninstall the old one from the server dashboard > Plugins, and probably restart the server. If you're installing the v5 plugin you unzip the file to give a .dll and install in C:\Users\username\AppData\Roaming\Emby-Server\plugins\ and restart the server.
arrbee99 1836 Posted September 17, 2019 Posted September 17, 2019 You mean this ? Bit weird. Still plays stuff here for me though.
rancid_ 1 Posted September 17, 2019 Author Posted September 17, 2019 (edited) I have everything up and running. I have no idea why, but updating to v5 and the new plugin fixed all my issues. Thx for sticking with me while I figured this out, super happy at the moment. Edited September 17, 2019 by rancid_
emveepee 133 Posted September 28, 2019 Posted September 28, 2019 You mean this ? Bit weird. Still plays stuff here for me though. What specifically is weird that I should look at? Martin
arrbee99 1836 Posted September 28, 2019 Posted September 28, 2019 It was, and still is - if I just go to that plugin page I get that spinning circle, which just keeps spinning as long as you stay there.
pünktchen 1410 Posted September 28, 2019 Posted September 28, 2019 What specifically is weird that I should look at? Martin The javascript code of the config page needs some update. Just look at the last commits for the MediaPortal plugin in Emby's github repos.
emveepee 133 Posted September 29, 2019 Posted September 29, 2019 The javascript code of the config page needs some update. Just look at the last commits for the MediaPortal plugin in Emby's github repos. Thanks both of you, I haven't run Emby for a few months and the installed version 4.1.0 works fine as well as the update 4.2.1.0 Is this a beta only change and will it break production use? Martin
Luke 42239 Posted September 29, 2019 Posted September 29, 2019 Yes what you could do to avoid an update that will change your min required server version is simply to keep the version targeting as it is, and update javascript to remove uses of the jquery functions $(...).selectmenu() and $(..).checked(), and $(...).checkboxradio(...). So essentially just convert those to vanilla js and then the same dll should work with both newer and older server versions.
emveepee 133 Posted September 29, 2019 Posted September 29, 2019 Thanks for confirming that Luke. Martin
