evewatchesstuff 1 Posted September 16, 2019 Posted September 16, 2019 So I've made a bunch of metadata edits, grouped tons of extras into single 'items', assigned posters that aren't the default selected ones etc. If I copy all the stuff in my docker 'emby' folder, do I keep all those edits if I migrate elsewhere or need to restore? Thanks!
rbjtech 5338 Posted September 16, 2019 Posted September 16, 2019 (edited) If you have not saved metadata with the media then yes - everything is kept in the emby folder/subfolders. Of course being docker/vm - the best way to acknowledge everything 'works' as expected is just create a 2nd instance of emby, change the listening port to something else and make sure you can fully restore the service without needing to impact your existing setup.. Edited September 16, 2019 by rbjtech
