Paint 10 Posted September 15, 2019 Posted September 15, 2019 (edited) please delete this topic, I resolved it on my end. It was an issue with my "Access-Control-Allow-Headers" setting in NGINX Edited September 17, 2019 by Paint
Luke 42242 Posted September 16, 2019 Posted September 16, 2019 Hi there, I would suggest checking out our connection troubleshooter: https://github.com/MediaBrowser/Wiki/wiki/Connectivity Please try the steps listed there and let us know which ones succeed and which ones do not. Thanks.
Paint 10 Posted September 16, 2019 Author Posted September 16, 2019 (edited) <Delete post> Edited September 17, 2019 by Paint
Paint 10 Posted September 17, 2019 Author Posted September 17, 2019 Thanks for the feedback ! I think we should expand the doc on connection issues/debugging. Users should try to use https://app.emby.media web-app and then use the manual connect to server with the Chrome debugger to help diagnose connection issues. This helped me resolve this and other issues I've had with connections and reverse proxies.
