Guest asrequested Posted November 18, 2019 Posted November 18, 2019 I have codec intros playing right after it, if that makes any difference?
Guest asrequested Posted November 18, 2019 Posted November 18, 2019 I did notice that he has smart parental control, enabled. Would that make a difference?
Luke 42217 Posted November 18, 2019 Posted November 18, 2019 I did notice that he has smart parental control, enabled. Would that make a difference? For custom intros, no.
MrPippali 1 Posted November 18, 2019 Author Posted November 18, 2019 Great, thanks for doing that. @@MrPippali, what version of Emby Theater are you running? 1.1.273.0 should be the latest on everything
PuffyToesToo 346 Posted November 18, 2019 Posted November 18, 2019 (edited) I just wanted to add that I am having the same problem. The only way to get anything to play was to disable the cinema intro. This also is happening on my bf's system, so I don't know if it's an isolated issue. I have been using the exact same intro for a year now, and it's only 10 seconds long. Never had any issues whatsoever until ~about the last week. Edited November 18, 2019 by PuffyToesToo
Luke 42217 Posted November 18, 2019 Posted November 18, 2019 I just wanted to add that I am having the same problem. The only way to get anything to play was to disable the cinema intro. This also is happening on my bf's system, so I don't know if it's an isolated issue. I have been using the exact same intro for a year now, and it's only 10 seconds long. Never had any issues whatsoever until ~about the last week. Please answer the same questions that we've asked earlier in this topic. Thanks.
