MrPippali 1 Posted September 14, 2019 Posted September 14, 2019 So I am having trouble with my pre-movie trailers in cinema mode on everything but the web browser. The playback will play the trailer and then either hang there or just stop. Have had a look in the dashboard while it happens and it doesn't seem even to try to start transcoding/playing the movie. I am using a set of custom 2-5 second trailers that appear before movies only resolution i have found is to turn it off for now but would realy like to keep using it logs atached and even willing to read other articles to try fix but its been 2 days of searching with no luck sofar embyserver.txt
Luke 42217 Posted September 15, 2019 Posted September 15, 2019 Hi there, what time was the playback attempt here?
MrPippali 1 Posted September 15, 2019 Author Posted September 15, 2019 woops... sorry about that...started the problem solving at 0834 and i turned off the trailers arround 0848/0900ish
ebr 16313 Posted September 15, 2019 Posted September 15, 2019 Hi. It looks like part of your test was with Android TV. Can you please follow the instructions to send a log from the app after recreating this issue? Thanks.
DoubleDD 5 Posted November 8, 2019 Posted November 8, 2019 Hi there, I'm having the exact same issue with Emby Theater. I use tags to play a specific intro video. After the intro video is complete it attempts to start the movie but all I get is the movie background with the spinning circle. I've tried this on several movies and on different PCs with the same results. Attached is my log file. Thanks
DoubleDD 5 Posted November 8, 2019 Posted November 8, 2019 Sorry about that...doesn't look like my file got attached in the previous post... hopefully its attached in this one... embyserver.zip
MrPippali 1 Posted November 8, 2019 Author Posted November 8, 2019 i havent been able to get the tv to submit the report it has kept crashing on submiti have planed to try again this coming weekend
Luke 42217 Posted November 15, 2019 Posted November 15, 2019 @, are you seeing this with your custom intros?
Guest asrequested Posted November 15, 2019 Posted November 15, 2019 It's working ok for me, in Theater. I tried a range combinations of settings. The only issue that I saw was that sometimes it didn't play one of my intros.
Luke 42217 Posted November 15, 2019 Posted November 15, 2019 Thanks ! @@DoubleDD @@MrPippali Are you still running into this?
MrPippali 1 Posted November 15, 2019 Author Posted November 15, 2019 (edited) I am yes sometimes it plays the intro, and sometimes it doesn't play anything just a spinny wheel till I restart the app on android ios and android tv webbrowser still works fine and my tv still keeps crashing the app when I try to submit the report sorry; i'll keep trying though EDIT: I just threw the intro into video's as an experiment to see if I could play it... this video run's the exact codec that I use for my movies, and I even reconverted it to make sure that it was the same as the movies I have on my server. And i can't play it... dose emby have a minimum length for videos iit can play?? @Doofus, how long are your intro's out of curiocity? mine is 3 sec at 5.5Mb (1263kbps), ".mp4" h.264 1080p if it helps I can even send you the clip Edited November 15, 2019 by MrPippali
Guest asrequested Posted November 15, 2019 Posted November 15, 2019 (edited) I doubt it's the length, but there's probably something else that those players don't like about it. Put it in a zip file and attach it. Edited November 15, 2019 by Doofus
MrPippali 1 Posted November 15, 2019 Author Posted November 15, 2019 this is the shortestFamily Media 1.zipthere are 5 veriants of this file with diffrent bg'sand 3 others but they are 15-20 sec and about 16~Mb
Guest asrequested Posted November 15, 2019 Posted November 15, 2019 I'll look at it, tonight. Mine are longer. I have codec and custom intros.
ebr 16313 Posted November 15, 2019 Posted November 15, 2019 That item does play fine on my Mi (although, the content makes it look like there's a problem ). It is possible it is somehow a timing problem in your environment though. Is it only this very short version that has the problem?
MrPippali 1 Posted November 15, 2019 Author Posted November 15, 2019 they all have the same problemand sory i should have warned you about the glitch effect part fo it
ebr 16313 Posted November 15, 2019 Posted November 15, 2019 Do you have the framerate switching option turned on? That is something that delays playback start so, if so, try with it off.
MrPippali 1 Posted November 15, 2019 Author Posted November 15, 2019 @@Luke no there are 6 files this is one of 5 that are efectifly the same and 3 that are about 15 sec they all do the same thing@@ebr that's the one in the playing apps? i havent found one in the back end of the server
Luke 42217 Posted November 16, 2019 Posted November 16, 2019 Can you provide a sample intro for testing, and let us know which app that particular file has a problem in? Thanks.
MrPippali 1 Posted November 16, 2019 Author Posted November 16, 2019 the file is ziped above but here you go... Family Media 1.zip and its Android TV, Android Mobile, IOS, Fire Stick and chromecast that are having the problemwork's fine in webbrowser T&L_Slomo.zip
Luke 42217 Posted November 18, 2019 Posted November 18, 2019 Played fine on my Shield.... did you try it in theater?
Guest asrequested Posted November 18, 2019 Posted November 18, 2019 did you try it in theater? I tried it in desktop, store version and the online Theater (tv.emby.media).... it worked in all of them.
Luke 42217 Posted November 18, 2019 Posted November 18, 2019 Great, thanks for doing that. @@MrPippali, what version of Emby Theater are you running?
