topraider 0 Posted September 14, 2019 Posted September 14, 2019 I am using Emby theater in Windows 10. Whenever I go into movies or collection all box sets come up with the default cover art. I have tried everything to correct this delete images in the server. re-install CA nothing is working. all the single movies side covers come up correctly. Any suggestions need HELP.
Happy2Play 9814 Posted September 14, 2019 Posted September 14, 2019 Have you gone to the BoxSet tab in Treatments, as you are showing the default Metrocase for BoxSets.
topraider 0 Posted September 14, 2019 Author Posted September 14, 2019 It's setup for side cover in CA settings for box sets.
Solution Luke 42255 Posted September 15, 2019 Solution Posted September 15, 2019 Ok that coverart profile will apply to movies under d:\bluray movies, but not collections because collections are not folder-based. You would have to just edit the default profile so that it will apply to all collections. 1
