ricky_buyo 4 Posted September 14, 2019 Posted September 14, 2019 Hello to everybody I am new in the forum. I have just installed the emby app via usb and it works perfectly. However, I can't create the app shortcut. I go into the apps menu, I create it, but then it does not appear. My TV is a Samsung 50RU7105. Thanks a lot.
FrostByte 5453 Posted September 14, 2019 Posted September 14, 2019 Does it say "Add to Home" or "Added to Home" in Apps settings? Apps Settings Highlight Emby icon
ricky_buyo 4 Posted September 28, 2019 Author Posted September 28, 2019 Does it say "Add to Home" or "Added to Home" in Apps settings? Apps Settings Highlight Emby icon Yes, but I can't get on the home menu. I go back to the app, highlight the emby icon and it shows that it is already added to home (same as the image). However, I can't see it.
