SenatorIvy 18 Posted September 12, 2019 Posted September 12, 2019 I went into the other room to stop playback on a stream that for some reason the console doesn't give me the option to stop remotely (?) and when I moved the mouse, the pause and reverse/ff controls were large and in the center of the screen. I checked the version and it's 3.0.9, which is the same version I use on every other device, where the rw/pause/ff icons are down in the bottom with the rest of the controls (where they're supposed to be, and where I want them to be) What gives?
SenatorIvy 18 Posted September 12, 2019 Author Posted September 12, 2019 Aaah, I see. It is a Surface Pro 3, so yeah. Is there a way to disable this UI change on touch-enabled systems so I can have things be uniform?
SenatorIvy 18 Posted September 12, 2019 Author Posted September 12, 2019 The system is hooked up to a tv via hdmi.
Luke 42241 Posted September 12, 2019 Posted September 12, 2019 Ok then assuming you have the app set for TV display mode, then this is fixable. Thanks.
