playloud 10 Posted September 11, 2019 Posted September 11, 2019 Files that play through Emby WMC show up Dolby Digital or DTS on the receiver, which should mean Windows audio is configured correctly. The same movies are showing up as LPCM stereo when played through Emby Theater (Desktop). I am using SPDIF directly from PC to receiver. From other threads, I think I need a tweak to MPV settings? I have the LAV audio settings configured, but I believe this only affects Media Center, not Theater/MPV.
serpi 82 Posted September 11, 2019 Posted September 11, 2019 Did you enable the passthrough in Emby Theater audio settings?
playloud 10 Posted September 11, 2019 Author Posted September 11, 2019 I have tried both ways, passthrough enabled and disabled. Same result.
Luke 42241 Posted September 11, 2019 Posted September 11, 2019 What audio settings have you configured?
Guest asrequested Posted September 11, 2019 Posted September 11, 2019 (edited) Files that play through Emby WMC show up Dolby Digital or DTS on the receiver, which should mean Windows audio is configured correctly.Passthrough has nothing to do with Windows audio configuration, other than choosing the device. The software will get the equipment capabilities from the hardware, if available. You are using optical, so you can only pass basic AC3 and DTS. Only enable those in Theater. If that doesn't work, I'll have you set up logging and we'll see what's happening. Edited October 10, 2019 by Doofus
