Lonald 10 Posted September 11, 2019 Posted September 11, 2019 Hi all, I am collecting Opera discs and have noticed a problem with most of the above discs. I use CloneBD to make lossless backups and these .mkv files do not play properly on Emby Theater. They do play on Kodi. If AVC is used, the .mkv does work fine. When fast forward is used, the video advances to a point about 42 minutes into the recording and will then always start from that point. In working with technical support, one finding is that the Opus Arte discs do not follow all Blu Ray standards: I did find something unusual: the key frames are only every 8 seconds. That is an enormous amount of time in between key frames and I can imagine, that this would hamper seeking on some players. And since you made a lossless copy, CloneBD can't change that. Those 8 seconds are a violation of the Blu-ray specification (it requires at most 1s), so that disc is not quite spec conforming (this is not unusual for discs authored by small studios). Is this something that can be rectified in the Theater app? I am not sure that the above is the full answer, of course. Thanks!
Guest asrequested Posted September 11, 2019 Posted September 11, 2019 Where did you download the app from?
Luke 42241 Posted September 11, 2019 Posted September 11, 2019 Can you provide a copy of the media info from the web app? Thanks.
Lonald 10 Posted September 11, 2019 Author Posted September 11, 2019 Which web app? I'm easily confused.... Could you send a PM on this? Thanks!
Guest asrequested Posted September 12, 2019 Posted September 12, 2019 It might be easier if you just share the file
Lonald 10 Posted September 12, 2019 Author Posted September 12, 2019 Please be specific as to which file from which app and I can do so. "Media information" unfortunately does not mean much to me. Do you want a logfile from the .mkv that did not work properly? The .mkv file itself (large)? A log file from Emby? Some other file? Thanks, and sorry for the confusion!
Guest asrequested Posted September 12, 2019 Posted September 12, 2019 Any file that you are experiencing this, with. And the web app. Open a web browser, go to your server dashboard. Top left corner, click the home button. Find the video in question, and scroll to the bottom, you will see media info, like this
Luke 42241 Posted September 12, 2019 Posted September 12, 2019 Which web app? I'm easily confused.... Could you send a PM on this? Thanks! The web app that is built into your Emby Server, or the online web app: http://app.emby.media
Lonald 10 Posted September 12, 2019 Author Posted September 12, 2019 (edited) The media information is below. Of note, the disc plays properly through the web app. Hope this is what you were looking for! Thanks! Media Info Video Title1080p HEVCCodecHEVCProfileMainLevel123Resolution1920x1080Aspect ratio16:9AnamorphicNoInterlacedNoFramerate29.97Bitrate41,911 kbpsColor primariesbt709Color spacebt709Color transferbt709Pixel formatyuv420pRef frames1 Audio TitleItalian DTS 5.1 (Default)LanguageItalianCodecDTSProfileDTS-HD MALayout5.1Channels6 chSample rate48,000 HzBit depth24 bitDefaultYes Audio TitleItalian PCM_S24BE 2 chLanguageItalianCodecPCM_S24BEChannels2 chBitrate2,304 kbpsSample rate48,000 HzBit depth24 bitDefaultNo Subtitle TitleEnglish (Default PGSSUB)LanguageEnglishCodecPGSSUBDefaultYesForcedNoExternalNo Subtitle TitleItalian (PGSSUB)LanguageItalianCodecPGSSUBDefaultNoForcedNoExternalNo Containermkv PathP:\La Boheme (test)\La Boheme.mkv Size33836 MB Edited September 12, 2019 by Lonald
Guest asrequested Posted September 12, 2019 Posted September 12, 2019 Your problem is likely because it's HEVC. You're probably using the app from the windows store and you don't have the HEVC plugin. Try using this app https://emby.media/emby-theater.html
Lonald 10 Posted September 13, 2019 Author Posted September 13, 2019 (edited) I don't recall where I downloaded the app - most likely from the website originally, then upgraded as the app was upgraded. I've used Emby for a good number of years. I did follow the link and uploaded the app. The .mkv still does not work properly and also does not work on the web application. Media information: Media Info Split Versions Apart [newest] Video Title1080p H264CodecH264AVCYesProfileHighLevel41Resolution1920x1080Aspect ratio16:9AnamorphicNoInterlacedNoFramerate29.97Bitrate39,387 kbpsBit depth8 bitPixel formatyuv420pRef frames1NAL4 Audio TitleItalian DTS 5.1 (Default)LanguageItalianCodecDTSProfileDTS-HD MALayout5.1Channels6 chSample rate48,000 HzBit depth24 bitDefaultYes Audio TitleItalian PCM_S24BE 2 chLanguageItalianCodecPCM_S24BEChannels2 chBitrate2,304 kbpsSample rate48,000 HzBit depth24 bitDefaultNo Subtitle TitleEnglish (Default PGSSUB)LanguageEnglishCodecPGSSUBDefaultYesForcedNoExternalNo Subtitle TitleFrench (PGSSUB)LanguageFrenchCodecPGSSUBDefaultNoForcedNoExternalNo Subtitle TitleItalian (PGSSUB)LanguageItalianCodecPGSSUBDefaultNoForcedNoExternalNo Containermkv PathP:\L'Elisir D'Amore (2009)\L'Elisir D'Amore (2009) [newest].mkv Size34199 MB [old] Video Title1080i H264CodecH264AVCYesProfileHighLevel41Resolution1920x1080Aspect ratio16:9AnamorphicNoInterlacedYesFramerate29.97Bitrate40,937 kbpsBit depth8 bitPixel formatyuv420pRef frames1NAL4 Audio TitleItalian DTS 5.1 (Default)LanguageItalianCodecDTSProfileDTS-HD MALayout5.1Channels6 chSample rate48,000 HzBit depth24 bitDefaultYes Audio TitleItalian DTS 5.1LanguageItalianCodecDTSProfileDTSLayout5.1Channels6 chBitrate1,536 kbpsSample rate48,000 HzDefaultNo Audio TitleItalian PCM_S24LE 2 chLanguageItalianCodecPCM_S24LEChannels2 chBitrate2,304 kbpsSample rate48,000 HzBit depth24 bitDefaultNo Subtitle TitleEnglish (PGSSUB)LanguageEnglishCodecPGSSUBDefaultNoForcedNoExternalNo Subtitle TitleFrench (PGSSUB)LanguageFrenchCodecPGSSUBDefaultNoForcedNoExternalNo Subtitle TitleGerman (PGSSUB)LanguageGermanCodecPGSSUBDefaultNoForcedNoExternalNo Subtitle TitleSpanish (PGSSUB)LanguageSpanishCodecPGSSUBDefaultNoForcedNoExternalNo Subtitle TitleItalian (PGSSUB)LanguageItalianCodecPGSSUBDefaultNoForcedNoExternalNo Containermkv PathP:\L'Elisir D'Amore (2009)\L'Elisir D'Amore (2009) [old].mkv Size35548 MB Edited September 13, 2019 by Lonald
Guest asrequested Posted September 13, 2019 Posted September 13, 2019 Can you share one of the videos?
Luke 42241 Posted September 13, 2019 Posted September 13, 2019 also does not work on the web application What does this mean exactly?
Lonald 10 Posted September 14, 2019 Author Posted September 14, 2019 The problem with the copies is that if you fast forward at all, the movie advances around 40 minutes into the video. Once that occurs, the video cannot be returned to a time point prior to that 40 minute mark. That 40 minute point now becomes the de facto starting point of the video whenever you go to play it again. The Leawo player also has problems with the .mkv files, but Kodi and others do not. Examples are: L'Elisier D'Amore by the Glyndebourne with a disc date of 2010 on IMDB (TheMovieDB ID 32370) La Boheme by the Royal Opera House also dated 2010 on IMDB (IMDB ID tt3440246)
Luke 42241 Posted September 15, 2019 Posted September 15, 2019 It is possible to provide a sample file for testing? Thanks !
Lonald 10 Posted September 15, 2019 Author Posted September 15, 2019 Yes, of course. How large of a file can I attach? Thanks!
Guest asrequested Posted September 15, 2019 Posted September 15, 2019 Use a cloud drive like gdrive or dropbox, and attach the link.
Lonald 10 Posted September 15, 2019 Author Posted September 15, 2019 https://www.dropbox.com/s/ztj9q9pa5xbjcfo/La%20Boheme%20%282010%29%20%5BEmby%5D.mkv?dl=0 This is about 10 minutes of La Boheme. Thanks!
Luke 42241 Posted September 16, 2019 Posted September 16, 2019 @ are you able to reproduce with that?
Guest asrequested Posted September 16, 2019 Posted September 16, 2019 I haven't had a chance to test it, yet. I'll try and test it, tonight.
Guest asrequested Posted September 17, 2019 Posted September 17, 2019 mpv is definitely having some difficulty with it. I'll do more testing with it in little while.
Guest asrequested Posted September 17, 2019 Posted September 17, 2019 It's an odd one. AVC that's interlaced. Not very common...
Guest asrequested Posted September 17, 2019 Posted September 17, 2019 Looks like there may be an issue with the demuxer. [ 9.874][d][cplayer] Run command: seek, flags=73, args=[5.000000, relative, unused] [ 9.874][v][mkv] queuing seek to 18.509000 [ 9.898][v][mkv] execute seek (to 18.509000 flags 4) [ 9.899][v][mkv] seek done [ 10.626][d][cplayer] Run command: seek, flags=73, args=[5.000000, relative, unused] [ 10.626][v][mkv] queuing seek to 23.509000 [ 10.654][v][mkv] execute seek (to 23.509000 flags 4) [ 10.655][v][mkv] seek done [ 11.520][w][mkv] Too many packets in the demuxer packet queues: [ 11.520][w][mkv] video/0: 0 packets, 0 bytes [ 11.520][w][mkv] audio/1: 24584 packets, 155847936 bytes [ 11.520][w][mkv] sub/3: 106 packets, 1442816 bytes (lazy)
Guest asrequested Posted September 17, 2019 Posted September 17, 2019 (edited) Got it! You have to force the disc demuxer. --demuxer=+disc Here are the available demuxers; Available demuxers: demuxer: info: disc CD/DVD/BD wrapper edl Edit decision list cue CUE sheet rawaudio Uncompressed audio rawvideo Uncompressed video mkv Matroska libarchive libarchive wrapper rar Rar archive file lavf libavformat mf image files (mf) playlist Playlist file null null demuxer I think because it's a remuxed disc rip, that's what it needs. https://mpv.io/manual/master/#options-demuxer Edited September 17, 2019 by Doofus
