jmassaro87 28 Posted September 11, 2019 Posted September 11, 2019 Always heard WD > Seagate, but I like the small savings on the seagates, any recommendations out there? Going into a QNAP TS-451+. Sent from my iPhone using Tapatalk
rbjtech 5341 Posted September 11, 2019 Posted September 11, 2019 From my own personal experience over 30+ years in IT, Seagate disks are less reliable than the likes of Samsung (when they made HDD's), Toshiba, WD and Hitachi. I have many HDD's with 10 YEARS spin life and zero bad sectors and zero error reads but my older seagates have bad sectors and read errors (all of them) with a few terminal - that tells me something. Their newer HDD's may be better, but I gave up Seagate years ago. All my latest HDD's are the NAS range from Toshiba and I'm very pleased with them - zero bad sectors or read errors with the oldest one being spinning for 1603 days (~4.5 years..) according to SMART..
StewieGreen 160 Posted September 11, 2019 Posted September 11, 2019 (edited) I use Seagate Ironwolf 6TB drives, no problems so far. edit: I'm not in IT and my current setup is only about 2 years old. So take it for what it's worth Edited September 11, 2019 by adamstewiegreen
JaScoMa 34 Posted September 14, 2019 Posted September 14, 2019 Have the same setup, QNAP TS-451+ with four Seagate Ironwolf 4GB drives. No issues at all. One thing i did notice is that there were a number of updates for the QNAP when I first powered it one to fully see my drives. When configuring, make sure all firmware updates are done prior to creating the array, etc. Once I ensured the QNAP was up to date, there weren't any issues at all.
rbjtech 5341 Posted September 15, 2019 Posted September 15, 2019 As I said, just my experience - I'm sure they are fine now, but when spinning 24x7 for 5 years, come back and let us know ...
Jdiesel 1435 Posted September 15, 2019 Posted September 15, 2019 I have had great luck with the WD White Labels which are similar to Reds and in some cases are Reds. Anyone that is considering some large capacity drive owes it to themselves, and their wallets, to search "WD Mybook shucking". I have currently have five 8TB Mybook drives in my system with zero issues. 4
rbjtech 5341 Posted September 16, 2019 Posted September 16, 2019 (edited) I had to google what 'shucking' was lol - but yes, it's not a new thing that external HDD's are usually cheaper than buying the equivalent bare HDD - crazy but true. Probably a marketing incentive or something .. WD 8Tb External HDD - UK £130, WD 8Tb Bare HDD - UK £240 - that is some savings ! Edited September 16, 2019 by rbjtech
mastrmind11 722 Posted September 17, 2019 Posted September 17, 2019 (edited) FYI, BestBuy has the 8TB EasyStore's on sale for $140 now and the 10TB for $180. Gonna go collect a few today over lunch. edit: picked up a pair an shucked them in under 5 mins. They were the white label "red" version. Linux recognized them right away. We'll see. Edited September 18, 2019 by mastrmind11 1
Jdiesel 1435 Posted September 19, 2019 Posted September 19, 2019 The only issue you might run into with the white labels is that some PSU power connectors and backplanes have trouble powering up the drive. If that is the case a molex to SATA 15-pin power supply connector will fix that.
CBers 7554 Posted September 19, 2019 Posted September 19, 2019 From my own personal experience over 30+ years in IT, I had to google what 'shucking' was lol
mastrmind11 722 Posted September 20, 2019 Posted September 20, 2019 The only issue you might run into with the white labels is that some PSU power connectors and backplanes have trouble powering up the drive. If that is the case a molex to SATA 15-pin power supply connector will fix that. Yeah was prepared for that. Planned to tape pins 1-3. Luckily they were recognized off the bat so it was unnecessary.
BAlGaInTl 288 Posted September 20, 2019 Posted September 20, 2019 I have had great luck with the WD White Labels which are similar to Reds and in some cases are Reds. Anyone that is considering some large capacity drive owes it to themselves, and their wallets, to search "WD Mybook shucking". I have currently have five 8TB Mybook drives in my system with zero issues. I had to google what 'shucking' was lol - but yes, it's not a new thing that external HDD's are usually cheaper than buying the equivalent bare HDD - crazy but true. Probably a marketing incentive or something .. WD 8Tb External HDD - UK £130, WD 8Tb Bare HDD - UK £240 - that is some savings ! FYI, BestBuy has the 8TB EasyStore's on sale for $140 now and the 10TB for $180. Gonna go collect a few today over lunch. edit: picked up a pair an shucked them in under 5 mins. They were the white label "red" version. Linux recognized them right away. We'll see. I'm currently running 3x10TB WD White Label drives that I "shucked." I got them for around $160 each. Two for my array, and one for parity. The only issue you might run into with the white labels is that some PSU power connectors and backplanes have trouble powering up the drive. If that is the case a molex to SATA 15-pin power supply connector will fix that. Yeah was prepared for that. Planned to tape pins 1-3. Luckily they were recognized off the bat so it was unnecessary. I ran into this problem with my backplane. Taping pin 3 did the job for me.
Guest asrequested Posted September 20, 2019 Posted September 20, 2019 Side note, HGST are still the drives with the least failures. https://www.backblaze.com/blog/hard-drive-stats-q2-2019/
mastrmind11 722 Posted September 20, 2019 Posted September 20, 2019 Side note, HGST are still the drives with the least failures. https://www.backblaze.com/blog/hard-drive-stats-q2-2019/ So find me an external that contains them and I'll gladly shuck away.
Jdiesel 1435 Posted September 20, 2019 Posted September 20, 2019 (edited) You won't because WD bought HGST six years ago and have phased out the HGST branding. HGST is WD Edit: Before anyone states it, yes I know HGST and WD are/were different Edited September 20, 2019 by Jdiesel
mastrmind11 722 Posted September 20, 2019 Posted September 20, 2019 You won't because WD bought HGST six years ago and have phased out the HGST branding. HGST is WD Edit: Before anyone states it, yes I know HGST and WD are/were different thought I read that somewhere. cheers
Guest asrequested Posted September 21, 2019 Posted September 21, 2019 Yeah, but as far as I know they still operate as an independent company (I should say I HOPE they are still separate). Mine are still going strong.
Happy2Play 9811 Posted September 21, 2019 Posted September 21, 2019 (edited) By 2018, the HGST brand had been phased out, with its remaining products now marketed under the Western Digital name. https://en.wikipedia.org/wiki/HGST Products formerly branded as HGST and Tegile, as well as some commercial/enterprise SanDisk and WD, are transitioning to being branded as Western Digital. https://www.techrepublic.com/article/western-digital-spins-down-hgst-and-tegile-brands-in-hard-disk-market-shuffle/ Edited September 21, 2019 by Happy2Play
Guest asrequested Posted September 21, 2019 Posted September 21, 2019 Well crap! That sucks. I don't like WD
legallink 187 Posted September 22, 2019 Posted September 22, 2019 Toshiba drives are the class leader now.
