braddles69 7 Posted September 11, 2019 Posted September 11, 2019 Hi all, Just a quick question I am using Emby for WMC (always just like the look of it) on Win 10, and recently had to repair my OS.One of the pecularities of my hardware setup is that I have a TV tuner card, which I only use the IR receiver for to switch the HTPC on/off and navigate as a MCE Remote, I have setup the remote to toggle the desktop (minimising WMC) and then closing it, before sending a shutdown command. However, in the OS rebuild and all apps, I now have Emby for WMC responding to my * cmd to (mapped to shutdown WMC) as this is a remote key shortcut on the homescreen for the context menu. I cannot remember how I reassigned this key in Emby for WMC, any ideas? I need the * cmd for my shutdown and simply want to reassign the "context menu" remote key to something different like a 'Y" - something I don't use. Is this possible, maybe by editing an xml file? Thanks in advance for any help and suggestions
Luke 42237 Posted September 11, 2019 Posted September 11, 2019 Hi, @@ebr will know for sure but I'm not sure Emby for WMC has configurable key assignments.
Solution ebr 16331 Posted September 11, 2019 Solution Posted September 11, 2019 Hi. No these are not configurable in EMC so you must've changed it some other way. 1
braddles69 7 Posted September 14, 2019 Author Posted September 14, 2019 Thanks @@ebr, this just happens from homescreen, a peculiarity of my testing the new OS and apps, and how they respond to shutdown. We actually never exit back to homescreen before a shutdown, so all good, this is something that I never changed, only spotted it in this test. So all good, thanks for the quick responses guys, appreciate it.
