Dodgy Bob 45 Posted September 11, 2019 Posted September 11, 2019 Hi folks, Before I go into too much detail, perhaps I should start with a short and quick question: on the Samsung Smart TV app for Emby are you able to change the Home Screen layout when it is in 'Horizontal' format/mode? My Samsung is a UA55HU8500 running Emby v0.122 "(updated 2018-10-11)". I'm pretty sure this is an Orsay based TV. Kind regards, Dodgy Bob
FrostByte 5453 Posted September 11, 2019 Posted September 11, 2019 Go to Settings Home Screen Change Tv mode to horizontal/verticle
Dodgy Bob 45 Posted September 11, 2019 Author Posted September 11, 2019 Go to Settings Home Screen Change Tv mode to horizontal/verticle Hey FrostByte, Yep, done that. Specifically though, can the Horizontal format/mode be changed? For example, I have all Home Screen Sections set to "None", but in Horizontal mode everything is still there on the actual Home Screen. Perhaps I'm not explaining myself clearly enough - sorry. So If I have the Home Screen set to Vertical and all Home Screen Sections set to "None", then nothing shows up on the actual Home Screen ... well, the bare minimum does. If I have the Home Screen set to Horizontal and all Home Screen Sections set to "None", then everything is still there ... but I don't want it to be. Basically, I'd like to have the Horizontal Home Screen and the "Up Next" section, but that is all. I don't want all of the other fluff! Sorry, is that better explained? Kind regards, Dodgy Bob.
Luke 42242 Posted September 11, 2019 Posted September 11, 2019 Hi, no, the horizontal home screen does not have as much configuration as the vertical home screen. 1
Dodgy Bob 45 Posted September 11, 2019 Author Posted September 11, 2019 Hi, no, the horizontal home screen does not have as much configuration as the vertical home screen. Doh! OK, well that answers that then... Is there anything on the horizon to allow some configuration to the Horizontal Home Screen perchance?
Luke 42242 Posted September 11, 2019 Posted September 11, 2019 Well not immediately but we'll always adjust based on feedback. I would suggest opening a feature request topic.
Dodgy Bob 45 Posted September 11, 2019 Author Posted September 11, 2019 Well not immediately but we'll always adjust based on feedback. I would suggest opening a feature request topic. Nice! I'll do that. Thanks Luke 1
