Milldor 14 Posted September 10, 2019 Posted September 10, 2019 Using a media keyboard or remote to change volume affects Windows overall volume and Emby Theater internal volume at the same time. For example; If Emby theater volume is at 100% volume up will make Windows continually raise. When pressing volume down Windows and Emby will both reduce at the same time. Could the media keys be separate or modifiable to prevent this? 1
Luke 42239 Posted September 10, 2019 Posted September 10, 2019 Hi, yes I think this is probably something that needs future review. Thanks for the feedback.
jhoff80 94 Posted November 21, 2021 Posted November 21, 2021 This is still a problem. It ends up having double the effect it should, and depending on what other things you're doing on the device, it can put you into weird scenarios where the system volume is at 100 but Emby volume is low.
