chrispykreme 1 Posted September 9, 2019 Posted September 9, 2019 (edited) I rebuilt my server and reattached my iPad to the new server; all was fine, but several libraries were missing from the home screen. So... I click on my avatar, selected Home Screen and adjusted it, but the Downloads strip that used to show the files on my ipad went and I can't see how to get it back. I can still click the hamburger and choose My Downloads | Downloads but it was nice having them front and centre on the screen. I watch mainly offline on the train/plane so being able to select off the home screen was cool Should have said Emby for iOS 1.8.2 / Emby server 4.2.1.0 Edited September 9, 2019 by chrispykreme
Solution Luke 42242 Posted September 9, 2019 Solution Posted September 9, 2019 HI there, did you change your home screen settings? Make sure the My Media section is configured as the top section.
chrispykreme 1 Posted September 10, 2019 Author Posted September 10, 2019 HI there, did you change your home screen settings? Make sure the My Media section is configured as the top section. Thanks Luke That was the trick, I hadn't made the link between the My Media and the Downloads section All good now
