monkeyslapper 11 Posted September 8, 2019 Posted September 8, 2019 Hi there. I am wondering if there is program that will monitor my space/storage or even issues with my drive in emby or 3rd party that will allow me to remote to it using android app? or have website that i can access?? Any suggestion would be great! Monkeyslapper
igeoorge 26 Posted September 8, 2019 Posted September 8, 2019 Following this post. I would love to have that.
Guest asrequested Posted September 11, 2019 Posted September 11, 2019 I'm not exactly sure of what you want, but Stablebit Scanner will give you some of those abilities. https://stablebit.com/Scanner/Features 1
sh0rty 727 Posted January 4, 2020 Posted January 4, 2020 PRTG, you can host it yourself and can use it from anywhere... https://www.paessler.com/prtg 1
ezarate 0 Posted March 14, 2020 Posted March 14, 2020 Windows or Linux ? Linux you can use the smart tools for your distro, pull that data and use it somewhere else like: prometheus, kibana, etc. Also you can uset netdata: https://github.com/netdata/netdata/tree/master/collectors/python.d.plugin/smartd_log Netdata looks awesome for the time it take to setup. I'm working in a mini NOC view for all my devices and i have that also in mind. I'll post something later.
drashna 47 Posted April 7, 2020 Posted April 7, 2020 I'm not exactly sure of what you want, but Stablebit Scanner will give you some of those abilities. https://stablebit.com/Scanner/Features I'll second this. Also, recently we are working on stuff so you can remotely view and manage StableBit Scanner (and drivePool). Also, phpSysInfo is a "good" way to do this, as well.
Swynol 375 Posted April 18, 2020 Posted April 18, 2020 pulseway is pretty good, simple and easy https://www.pulseway.com/
