HaryTheLime 0 Posted September 8, 2019 Posted September 8, 2019 I was trying to convert my DVD mkvs using emby server preset TV. Everything works fine so fas, except additional audio tracks get converted instead of bein copied. I want to keep the AC3 audio, is there a way to accomplish this? I attached screenshots of the settings and the transcoding log as well. Thanks in advance for your help and best regards Hary ffmpeg-transcode-2b6d2e3e-8276-42c6-adf0-5fef22c51496_1.txt
Luke 42217 Posted September 8, 2019 Posted September 8, 2019 Hi, this is something we'll have to look at. I believe the logic around secondary tracks needs to be improved. Thanks.
