frostf 0 Posted September 7, 2019 Posted September 7, 2019 Использую Emby Server Version: 4.2.1.0 под Windows 7. Нужна помощь в настройке интернет-радио на телевизоре Sony Bravia KDL-42W706B через "Tune In" плагин. Проблема проявляется только на телевизоре, на остальных устройствах радио работает. Фильмы и музыку ТВ играет. Дайте знать, если нужна еще какая либо информация. Лог прилагается. error.txt Спасибо.
Luke 42239 Posted September 14, 2019 Posted September 14, 2019 Hi there, can you please attach the complete emby server log? Thinks.
frostf 0 Posted September 19, 2019 Author Posted September 19, 2019 Enable DLNA debug logging ON Enable debug logging ON embyserver-63704448000.txt
Luke 42239 Posted September 23, 2019 Posted September 23, 2019 Hi there, are you able to play the same content in the Emby web app?
frostf 0 Posted September 23, 2019 Author Posted September 23, 2019 Using the Emby web app everything works fine.
Luke 42239 Posted October 17, 2019 Posted October 17, 2019 Ok, we'll take a look at this. Thanks for reporting.
