SenatorIvy 18 Posted September 6, 2019 Posted September 6, 2019 I understand removing the show poster in the move to a cleaned up look, but why is it that I can no longer tell what season and episode I'm on? It shows episode but hides season on both the now playing and next up. I should be able to tell what season and episode I'm on at a glance. if there's room enough to put (HD) after the episode title for whatever reason, there's room enough to put sXXeXX at the front instead of just the episode number.
Luke 42241 Posted September 6, 2019 Posted September 6, 2019 That should still be there. Can you please show a screenshot? thanks. If it's missing in both places then it sounds like your metadata doesn't have this information.
SenatorIvy 18 Posted September 7, 2019 Author Posted September 7, 2019 I never had the problem with missing metadata before this update. Here is a screenshot of an episode clicked, where it has the info there (ie it knows that it's season 7, and what episode it is, etc) and then 2nd is a screenshot of the episode while playing.
SenatorIvy 18 Posted September 7, 2019 Author Posted September 7, 2019 Dunno why there's all that white artifacting in the shots there; it's not there while I'm watching. Must be a side effect of Greenshot taking screenshots of a hardware accelerated overlay or something.
Guest asrequested Posted September 7, 2019 Posted September 7, 2019 If you're using png images, that will sometimes happen
Luke 42241 Posted September 7, 2019 Posted September 7, 2019 Make sure the episode has a season number in the metadata.
Marc_G 95 Posted September 8, 2019 Posted September 8, 2019 The white stuff is color transparency probably set to be shown for full black in that file, and the transparent areas are displayed as white. It's a png thing as Doofus said.
Happy2Play 9811 Posted September 8, 2019 Posted September 8, 2019 Dunno why there's all that white artifacting in the shots there; it's not there while I'm watching. Must be a side effect of Greenshot taking screenshots of a hardware accelerated overlay or something. Yes this is a known issue with png images and the forum software.
