Aman3798 0 Posted September 5, 2019 Posted September 5, 2019 Hi Guys,I am totally new to emby I manage to create account with shared emby server from provider called monkey devices alternative to bacon feet.I have Nvidia shield 2017 model and internet’s speed well over 80 mbps. Now the main issue am seeing right now is pretty much all videos larger or small buffering or pausing every 2-3 seconds.I did try lowers speed for transcoding settings didn’t seem to make no difference,I did try option playback correction still nothing.I am using android tv emby app because I couldn’t connect to server on Nvidia shield app that I downloaded from emby website.But android tv app don’t seem to work any better for me. First 3-4days app emby worked absolutely fine for me and then don’t know what went wrong always buffering,cleared catche regularly too. Please help me to find fix with emby ,I got plex same time no issues at all just emby causing problems for me
Luke 42246 Posted September 5, 2019 Posted September 5, 2019 Hi, so this is not your Emby Server, correct? I would suggest lowering the in-app quality setting. What is it set to now?
Aman3798 0 Posted September 5, 2019 Author Posted September 5, 2019 Hi ,As mentioned above I did try lower it from playback settings to like 30 mbps also tried with auto no changes in terms of buffering
ebr 16338 Posted September 6, 2019 Posted September 6, 2019 30Mbs is still a very high limit for remote. Bottom line, though is that you probably need to talk to the owner of the server for direction here. Thanks.
Luke 42246 Posted September 6, 2019 Posted September 6, 2019 Yea I would try 1 mbps and then work your way up from there as you see success.
