zjeffer 6 Posted September 5, 2019 Posted September 5, 2019 Here are some examples:* https://i.imgur.com/i1089cv.png* https://i.imgur.com/J0B3Mfi.pngThis doesn't always happen, sometimes refreshing fixes the problem, but it happens enough to bother me. I'm using a Raspberry Pi 3 B+ as my server, using Firefox on Arch Linux to stream. It's as if it can't figure out which language it needs to display the strings inside the headers and buttons, so it defaults to the internal one. My display language is set to English (UK). What can I do to troubleshoot this problem? What info can I provide?
Luke 42242 Posted September 5, 2019 Posted September 5, 2019 Hi there, when it happens can you please supply the contents of the browser debug console? Thanks.
zjeffer 6 Posted September 5, 2019 Author Posted September 5, 2019 (edited) I changed some things to hide my IP and stuff, but here it is: SecurityError: The operation is insecure. appstorage-localstorage.js:1 Begin ConnectionManager constructor connectionmanager.js:1:3722 initAfterDependencies promises resolved app.js:1:11347 Using default fonts app.js:1:12674 Loading installed plugins app.js:1:12958 Loading plugin: bower_components/emby-webcomponents/playback/playbackvalidation pluginmanager.js:1:194 Loading plugin: bower_components/emby-webcomponents/playback/playaccessvalidation pluginmanager.js:1:194 Loading plugin: bower_components/emby-webcomponents/playback/experimentalwarnings pluginmanager.js:1:194 Loading plugin: bower_components/emby-webcomponents/htmlaudioplayer/plugin pluginmanager.js:1:194 Loading plugin: bower_components/emby-webcomponents/htmlvideoplayer/plugin pluginmanager.js:1:194 Loading plugin: bower_components/emby-webcomponents/photoplayer/plugin pluginmanager.js:1:194 Loading plugin: bower_components/emby-webcomponents/sessionplayer pluginmanager.js:1:194 Loading plugin: bower_components/emby-webcomponents/youtubeplayer/plugin pluginmanager.js:1:194 Setting page base to router.js:1:16016 ApiClient serverAddress: http://192.168.1.39:8096 apiclient.js:1:1530 ApiClient appName: Emby Web apiclient.js:1:1585 ApiClient appVersion: 4.2.0.50 apiclient.js:1:1628 ApiClient deviceName: Firefox apiclient.js:1:1677 ApiClient deviceId: TW96aWxsYS81LjAgKFgxMTsgTGludXggeDg2XzY0OyBydjo2OC4wKSBHZWNrby8yMDEwMDEwMSBGaXJlZm94LzY4LjB8MTU2NjE2MzkxNDE0Mg11 apiclient.js:1:1726 returning instance from getOrAddApiClient connectionmanager.js:1:14872 Begin onAppReady app.js:1:14680 onAppReady - loading dependencies app.js:1:15052 Loaded dependencies in onAppReady app.js:1:15144 Defining core routes app.js:1:15330 Defining route: /plugins/addplugin.html router.js:1:15506 Defining route: /channelsettings.html router.js:1:15506 Defining route: /startup/connectlogin.html router.js:1:15506 Defining route: /startup/connectsignup.html router.js:1:15506 Defining route: /startup/welcome.html router.js:1:15506 Defining route: /dashboard.html router.js:1:15506 Defining route: /dashboardgeneral.html router.js:1:15506 Defining route: /dashboardhosting.html router.js:1:15506 Defining route: /devices/devices.html router.js:1:15506 Defining route: /devices/device.html router.js:1:15506 Defining route: /devicesupload.html router.js:1:15506 Defining route: /edititemmetadata.html router.js:1:15506 Defining route: /encodingsettings.html router.js:1:15506 Defining route: /startup/forgotpassword.html router.js:1:15506 Defining route: /startup/forgotpasswordpin.html router.js:1:15506 Defining route: /home.html router.js:1:15506 Defining route: /list/list.html router.js:1:15506 Defining route: /servermenu/servermenu.html router.js:1:15506 Defining route: /index.html router.js:1:15506 Defining route: /item/item.html router.js:1:15506 Defining route: /librarysetup/library.html router.js:1:15506 Defining route: /librarysetup/advanced.html router.js:1:15506 Defining route: /livetv/livetv.html router.js:1:15506 Defining route: /livetvsetup/schedulesdirect.html router.js:1:15506 Defining route: /livetvsetup/xmltv.html router.js:1:15506 Defining route: /livetvsetup/embydata.html router.js:1:15506 Defining route: /livetvsetup/guideprovider.html router.js:1:15506 Defining route: /livetvsetup/livetvsettings.html router.js:1:15506 Defining route: /livetvsetup/livetvstatus.html router.js:1:15506 Defining route: /livetvsetup/livetvtuner.html router.js:1:15506 Defining route: /logs/logs.html router.js:1:15506 Defining route: /startup/login.html router.js:1:15506 Defining route: /startup/manuallogin.html router.js:1:15506 Defining route: /metadataadvanced.html router.js:1:15506 Defining route: /librarysetup/metadata.html router.js:1:15506 Defining route: /movies/movies.html router.js:1:15506 Defining route: /games/games.html router.js:1:15506 Defining route: /homevideos/homevideos.html router.js:1:15506 Defining route: /musicvideos/musicvideos.html router.js:1:15506 Defining route: /music/music.html router.js:1:15506 Defining route: /offline/offline.html router.js:1:15506 Defining route: /managedownloads.html router.js:1:15506 Defining route: /mysync.html router.js:1:15506 Defining route: /mysyncjob.html router.js:1:15506 Defining route: /notificationsetting.html router.js:1:15506 Defining route: /notificationsettings.html router.js:1:15506 Defining route: /nowplaying/nowplaying.html router.js:1:15506 Defining route: /plugins/plugincatalog.html router.js:1:15506 Defining route: /plugins/plugins.html router.js:1:15506 Defining route: /scheduledtasks/scheduledtask.html router.js:1:15506 Defining route: /dashboard/releasenotes.html router.js:1:15506 Defining route: /scheduledtasks/scheduledtasks.html router.js:1:15506 Defining route: /search/search.html router.js:1:15506 Defining route: /startup/manualserver.html router.js:1:15506 Defining route: /startup/selectserver.html router.js:1:15506 Defining route: /serveractivity.html router.js:1:15506 Defining route: /serversecurity.html router.js:1:15506 Defining route: /support.html router.js:1:15506 Defining route: /supporterkey.html router.js:1:15506 Defining route: /syncactivity.html router.js:1:15506 Defining route: /syncsettings.html router.js:1:15506 Defining route: /tv/tv.html router.js:1:15506 Defining route: /useredit.html router.js:1:15506 Defining route: /userlibraryaccess.html router.js:1:15506 Defining route: /usernew.html router.js:1:15506 Defining route: /userparentalcontrol.html router.js:1:15506 Defining route: /userpassword.html router.js:1:15506 Defining route: /users/users.html router.js:1:15506 Defining route: /settings/settings.html router.js:1:15506 Defining route: /settings/playback.html router.js:1:15506 Defining route: /settings/subtitles.html router.js:1:15506 Defining route: /settings/display.html router.js:1:15506 Defining route: /settings/homescreen.html router.js:1:15506 Defining route: /settings/profile.html router.js:1:15506 Defining route: /settings/password.html router.js:1:15506 Defining route: /wizard/wizardagreement.html router.js:1:15506 Defining route: /wizard/wizardremoteaccess.html router.js:1:15506 Defining route: /wizard/wizardfinish.html router.js:1:15506 Defining route: /wizard/wizardlibrary.html router.js:1:15506 Defining route: /wizard/wizardsettings.html router.js:1:15506 Defining route: /wizard/wizardstart.html router.js:1:15506 Defining route: /wizard/wizarduser.html router.js:1:15506 Defining route: /videoosd/videoosd.html router.js:1:15506 Defining route: /configurationpageext router.js:1:15506 Defining route: / router.js:1:15506 validateFeature: themes registrationservices.js:1:14172 returning instance from getOrAddApiClient connectionmanager.js:1:14872 Begin connect connectionmanager.js:1:27221 Begin getAvailableServers connectionmanager.js:1:16233 Begin getConnectServers connectionmanager.js:1:16372 ConnectionManager requesting url: https://mb3admin.com/admin/service/registration/validateDevice?serverId=0f67a6f9abd04d1bb5dcc44dea31c404&deviceId=TW96aWxsYS81LjAgKFgxMTsgTGludXggeDg2XzY0OyBydjo2OC4wKSBHZWNrby8yMDEwMDEwMSBGaXJlZm94LzY4LjB8MTU2NjE2MzkxNDE0Mg11&deviceName=Firefox&appName=Emby%20Web&appVersion=4.2.0.50&embyUserName=MYUSERNAME&viewOnly=true connectionmanager.js:1:2435 Begin connectToServers, with 1 servers connectionmanager.js:1:18432 begin connectToServer connectionmanager.js:1:18981 tryReconnect: http://192.168.1.39:8096|http://192.168.1.54:8096|http://MY.IP.XX.XX:8096 connectionmanager.js:1:7874 tryReconnectToUrl: http://192.168.1.39:8096 connectionmanager.js:1:6445 tryReconnectToUrl: http://192.168.1.54:8096 connectionmanager.js:1:6445 tryReconnectToUrl: http://MY.IP.XX.XX:8096 connectionmanager.js:1:6445 ConnectionManager requesting url: http://192.168.1.39:8096/emby/system/info/public connectionmanager.js:1:2435 fetchWithTimeout: timeoutMs: 20000, url: http://192.168.1.39:8096/emby/system/info/public connectionmanager.js:1:1776 ConnectionManager requesting url: http://192.168.1.54:8096/emby/system/info/public connectionmanager.js:1:2435 fetchWithTimeout: timeoutMs: 20000, url: http://192.168.1.54:8096/emby/system/info/public connectionmanager.js:1:1776 fetchWithTimeout: succeeded connecting to url: http://192.168.1.39:8096/emby/system/info/public connectionmanager.js:1:2036 ConnectionManager response status: 200, url: http://192.168.1.39:8096/emby/system/info/public connectionmanager.js:1:2553 ConnectionManager requesting url: http://192.168.1.39:8096/emby/System/Info connectionmanager.js:1:2435 fetchWithTimeout: succeeded connecting to url: http://192.168.1.54:8096/emby/system/info/public connectionmanager.js:1:2036 ConnectionManager response status: 200, url: http://192.168.1.54:8096/emby/system/info/public connectionmanager.js:1:2553 ConnectionManager response status: 200, url: http://192.168.1.39:8096/emby/System/Info connectionmanager.js:1:2553 returning instance from getOrAddApiClient connectionmanager.js:1:14872 Setting server address to http://192.168.1.39:8096 apiclient.js:1:17036 calling apiClient.ensureWebSocket connectionmanager.js:1:5043 opening web socket with url: ws://192.168.1.39:8096/embywebsocket?api_key=ed529dd6eaaa4067a8a6b8dc80081a33&deviceId=TW96aWxsYS81LjAgKFgxMTsgTGludXggeDg2XzY0OyBydjo2OC4wKSBHZWNrby8yMDEwMDEwMSBGaXJlZm94LzY4LjB8MTU2NjE2MzkxNDE0Mg11 apiclient.js:1:14294 returning instance from getOrAddApiClient connectionmanager.js:1:14872 Requesting http://192.168.1.39:8096/emby/DisplayPreferences/usersettings?userId=cec342ed0ec1477b86ee99402f41d2c0&client=emby apiclient.js:1:6853 web socket connection opened apiclient.js:1:14507 Requesting url without automatic networking: http://192.168.1.39:8096/emby/Sessions/Capabilities/Full apiclient.js:1:8574 ConnectionManager requesting url: http://MY.IP.XX.XX:8096/emby/system/info/public connectionmanager.js:1:2435 fetchWithTimeout: timeoutMs: 20000, url: http://MY.IP.XX.XX:8096/emby/system/info/public connectionmanager.js:1:1776 Requesting http://192.168.1.39:8096/emby/Users/cec342ed0ec1477b86ee99402f41d2c0 apiclient.js:1:6853 validateFeature: themes registrationservices.js:1:14172 resolving connectToServers with result.State: SignedIn connectionmanager.js:1:18702 ConnectionManager requesting url: https://mb3admin.com/admin/service/registration/validateDevice?serverId=0f67a6f9abd04d1bb5dcc44dea31c404&deviceId=TW96aWxsYS81LjAgKFgxMTsgTGludXggeDg2XzY0OyBydjo2OC4wKSBHZWNrby8yMDEwMDEwMSBGaXJlZm94LzY4LjB8MTU2NjE2MzkxNDE0Mg11&deviceName=Firefox&appName=Emby%20Web&appVersion=4.2.0.50&embyUserName=MYUSERNAME&viewOnly=true connectionmanager.js:1:2435 appRouter - processing path request / router.js:1:4067 appRouter - user is authenticated router.js:1:4570 appRouter - loading skin home page router.js:1:4978 appRouter - processing path request /home.html router.js:1:4067 appRouter - user is authenticated router.js:1:4570 appRouter - proceeding to /home.html router.js:1:5577 Requesting http://192.168.1.39:8096/emby/Users/cec342ed0ec1477b86ee99402f41d2c0 apiclient.js:1:6853 Requesting http://192.168.1.39:8096/emby/Users/cec342ed0ec1477b86ee99402f41d2c0/Views apiclient.js:1:6853 validateFeature: livetv registrationservices.js:1:14172 Requesting http://192.168.1.39:8096/emby/LiveTv/Channels?userId=cec342ed0ec1477b86ee99402f41d2c0&limit=1&ImageTypeLimit=1&EnableTotalRecordCount=false&EnableImages=false&EnableUserData=false apiclient.js:1:6853 ConnectionManager requesting url: https://mb3admin.com/admin/service/registration/validateDevice?serverId=0f67a6f9abd04d1bb5dcc44dea31c404&deviceId=TW96aWxsYS81LjAgKFgxMTsgTGludXggeDg2XzY0OyBydjo2OC4wKSBHZWNrby8yMDEwMDEwMSBGaXJlZm94LzY4LjB8MTU2NjE2MzkxNDE0Mg11&deviceName=Firefox&appName=Emby%20Web&appVersion=4.2.0.50&embyUserName=MYUSERNAME&viewOnly=true connectionmanager.js:1:2435 ConnectionManager response status: 404, url: https://mb3admin.com/admin/service/registration/validateDevice?serverId=0f67a6f9abd04d1bb5dcc44dea31c404&deviceId=TW96aWxsYS81LjAgKFgxMTsgTGludXggeDg2XzY0OyBydjo2OC4wKSBHZWNrby8yMDEwMDEwMSBGaXJlZm94LzY4LjB8MTU2NjE2MzkxNDE0Mg11&deviceName=Firefox&appName=Emby%20Web&appVersion=4.2.0.50&embyUserName=MYUSERNAME&viewOnly=true connectionmanager.js:1:2553 getRegistrationInfo response: 404 connectionmanager.js:1:25657 ConnectionManager response status: 404, url: https://mb3admin.com/admin/service/registration/validateDevice?serverId=0f67a6f9abd04d1bb5dcc44dea31c404&deviceId=TW96aWxsYS81LjAgKFgxMTsgTGludXggeDg2XzY0OyBydjo2OC4wKSBHZWNrby8yMDEwMDEwMSBGaXJlZm94LzY4LjB8MTU2NjE2MzkxNDE0Mg11&deviceName=Firefox&appName=Emby%20Web&appVersion=4.2.0.50&embyUserName=MYUSERNAME&viewOnly=true connectionmanager.js:1:2553 getRegistrationInfo response: 404 connectionmanager.js:1:25657 Requesting http://192.168.1.39:8096/emby/Users/cec342ed0ec1477b86ee99402f41d2c0/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video apiclient.js:1:6853 Requesting http://192.168.1.39:8096/emby/Users/cec342ed0ec1477b86ee99402f41d2c0/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio apiclient.js:1:6853 Requesting http://192.168.1.39:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=cec342ed0ec1477b86ee99402f41d2c0&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false apiclient.js:1:6853 Requesting http://192.168.1.39:8096/emby/Users/cec342ed0ec1477b86ee99402f41d2c0/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805 apiclient.js:1:6853 Requesting http://192.168.1.39:8096/emby/Users/cec342ed0ec1477b86ee99402f41d2c0/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=6c2a057148b4d7c20a207c789aba6d07 apiclient.js:1:6853 ConnectionManager response status: 404, url: https://mb3admin.com/admin/service/registration/validateDevice?serverId=0f67a6f9abd04d1bb5dcc44dea31c404&deviceId=TW96aWxsYS81LjAgKFgxMTsgTGludXggeDg2XzY0OyBydjo2OC4wKSBHZWNrby8yMDEwMDEwMSBGaXJlZm94LzY4LjB8MTU2NjE2MzkxNDE0Mg11&deviceName=Firefox&appName=Emby%20Web&appVersion=4.2.0.50&embyUserName=MYUSERNAME&viewOnly=true connectionmanager.js:1:2553 getRegistrationInfo response: 404 connectionmanager.js:1:25657 The Notification permission may only be requested in a secure context. app.emby.media This site appears to use a scroll-linked positioning effect. This may not work well with asynchronous panning; see https://developer.mozilla.org/docs/Mozilla/Performance/ScrollLinkedEffects for further details and to join the discussion on related tools and features! app.emby.media Edited September 5, 2019 by zjeffer
zjeffer 6 Posted September 7, 2019 Author Posted September 7, 2019 Yes, but I just found out it seems to only have the problem when going to app.emby.media, instead of my local or public IP.
