lightsout 156 Posted September 5, 2019 Posted September 5, 2019 I am trying to understand the behavior when all the tuners are being used. I have a single prime with 3 tuners. I started 3 recordings, and tried to watch a 4th channel. Usually on a standard dvr you will get a pop up and you can then choose if you want to stop one of the recordings to tune to the desired channel. What I got instead was a loading circle that went for a while and then eventually just stopped. Nothing happened. I am connecting remotely with Chrome so that may have an impact here. But ma curious is this the intended behavior? Was hoping for a choice to close a recording because if not the WAF is pretty low as she has to then go figure out where the active recordings are and cancel one. Did I miss something?
Luke 42244 Posted September 5, 2019 Posted September 5, 2019 Hi, yes this is something that needs to be improved. Thanks.
lightsout 156 Posted September 5, 2019 Author Posted September 5, 2019 Hi, yes this is something that needs to be improved. Thanks. Ok thanks for the quick reply Luke.
Sammy 791 Posted September 5, 2019 Posted September 5, 2019 Did I miss something? Yes.. more tuners! [emoji6] Sent from my SM-G960U1 using Tapatalk
Sammy 791 Posted September 5, 2019 Posted September 5, 2019 Sorry. I couldn't help myself! LOL Sent from my SM-G960U1 using Tapatalk
lightsout 156 Posted September 5, 2019 Author Posted September 5, 2019 Yes.. more tuners! [emoji6] Sent from my SM-G960U1 using Tapatalk Ha dude I know I was on eBay this morning looking. Should have taken you up on that but didn't have the funds. I upgraded to select and set a couple shows and already seeing conflicts. I'll add three more here in the next month. 1
