moneycwq 2 Posted September 5, 2019 Posted September 5, 2019 媒体数据库扫描不正常,仅适用于纪录片。我的纪录片尝试了类似的电影结构,电视结构和混合结构问题。扫描和识别完全不正常。例如,纪录片,名称和imdb都有数字,我也使用imdb作为设置中的第一选择。但是,无法识别输入文档的名称或imdb的数量。例如:在欧洲天空下,相应的imdb编号为tt0980479,但手动编辑数据库,选择标识,无论输入名称或输入imdb编号或两者,反馈都无法识别。还有一个蓝色的海洋,一个蓝灯mkv,只显示没有识别选项的文件夹。我很困惑,我该怎么办?我的纪录片是一个单独的媒体库。我应该选择什么类型?电影?电视?混合? 注意:我是首映用户 迫切等待emby的帮助!!! [附件= 59977:1.JPG]
Luke 42217 Posted September 5, 2019 Posted September 5, 2019 Hi there, have you compared to the movie naming guide on our wiki? https://github.com/MediaBrowser/Wiki/wiki/Movie-naming 1
moneycwq 2 Posted September 5, 2019 Author Posted September 5, 2019 My problem is not caused by naming. I manually edited the media library, entered the standard movie name and IMDB number in the recognition page, and still showed that the video could not be searched.
moneycwq 2 Posted September 5, 2019 Author Posted September 5, 2019 Hi there, have you compared to the movie naming guide on our wiki? https://github.com/MediaBrowser/Wiki/wiki/Movie-naming hi. My problem is not caused by naming. I manually edited the media library, entered the standard movie name and IMDB number in the recognition page, and still showed that the video could not be searched.
Happy2Play 9806 Posted September 6, 2019 Posted September 6, 2019 You can not enter metadata on a folder. Do you see the actual file when you expand the BDMV folder? Also note IMDB is never used as they do not have a free api. The imdb id is only used to query item via TMDB and OMDB depending on your library settings. And only returns results if that id is found via their api search.
moneycwq 2 Posted September 6, 2019 Author Posted September 6, 2019 Try entering the MovieDb id instead. You can not enter metadata on a folder. Do you see the actual file when you expand the BDMV folder? Also note IMDB is never used as they do not have a free api. The imdb id is only used to query item via TMDB and OMDB depending on your library settings. And only returns results if that id is found via their api search. thanks。First, expand the folder to have the actual file. Once it is placed in the movie media library, it can automatically recognize the playback. Secondly, the MovieDb ID can not be searched. Finally, in order to search, I added all the metadata databases that can be used in emby. For example, imdb, douban, tvdb, etc. What should I do now? I always recognize the video on the recognition page. And this problem only appears in the documentary, other movies, TV media library is normal. I have such a problem no matter what structure I use to deal with the documentary.
moneycwq 2 Posted September 6, 2019 Author Posted September 6, 2019 what should I do now? I always recognize the video on the recognition page. And this movie may be recognized in the movie media library. But if I use a movie media library, then the documentary has many unidentified TV structures. If you put it in the TV media library, some Blu-ray will not be recognized. . . . File naming is in accordance with emby naming rules
Happy2Play 9806 Posted September 6, 2019 Posted September 6, 2019 You will probably have to post a server log so we can see the search queries you are doing. IMDB is not a metadata option anywhere in Emby. Going off the image you posted above what do you see when you expand BDMV folder? I assume you see the file as you can not apply or search for metadata on the folder you have highlighted in that image as that is only a folder.
moneycwq 2 Posted September 7, 2019 Author Posted September 7, 2019 You will probably have to post a server log so we can see the search queries you are doing. IMDB is not a metadata option anywhere in Emby. Going off the image you posted above what do you see when you expand BDMV folder? I assume you see the file as you can not apply or search for metadata on the folder you have highlighted in that image as that is only a folder. If I put this Blu-ray folder into the movie media library, I can recognize that it can be played, and in the documentary media library (mixed structure) is a folder. This option does not appear to be recognized. On the one hand, the documentary media library does not recognize the BDMV film. On the other hand, it does not allow me to manually edit and identify. In addition, there are some documentaries that cannot be recognized by hand editing anyway. I really don't know what to do. I will collect the logs and put them up.
Luke 42217 Posted September 7, 2019 Posted September 7, 2019 媒体数据库扫描不正常,仅适用于纪录片。我的纪录片尝试了类似的电影结构,电视结构和混合结构问题。扫描和识别完全不正常。例如,纪录片,名称和imdb都有数字,我也使用imdb作为设置中的第一选择。但是,无法识别输入文档的名称或imdb的数量。例如:在欧洲天空下,相应的imdb编号为tt0980479,但手动编辑数据库,选择标识,无论输入名称或输入imdb编号或两者,反馈都无法识别。还有一个蓝色的海洋,一个蓝灯mkv,只显示没有识别选项的文件夹。我很困惑,我该怎么办?我的纪录片是一个单独的媒体库。我应该选择什么类型?电影?电视?混合? 注意:我是首映用户 迫切等待emby的帮助!!! [附件= 59977:1.JPG] Try taking out the MakeMKV sub-folder and then run a library scan and see if that helps.
