Happy2Play 9806 Posted September 6, 2019 Posted September 6, 2019 I have no idea, I am totally lost.......... Is Emby public port set to 80 also But personally don't know how the public/local port mismatch works. Post screenshot of your router's portfowarding config. Did you see post 19?
Guest asrequested Posted September 6, 2019 Posted September 6, 2019 Did you see post 19? I hadn't, thanks. Yeah, why did you use port 80????
clarkss12 304 Posted September 6, 2019 Author Posted September 6, 2019 I hadn't, thanks. Yeah, why did you use port 80???? It wouldn't do anything until I put a number in there. So I grabbed a common port and stuck it in there. I have no clue what I'm doing.
Guest asrequested Posted September 6, 2019 Posted September 6, 2019 It should be the same port in both fields.
clarkss12 304 Posted September 6, 2019 Author Posted September 6, 2019 (edited) It should be the same port in both fields.Thanks, I will try that tomorrow. Now it's bedtime. Edit:. That gave me access, thanks. But live TV still does not work. Recordings play fine. Edited September 6, 2019 by clarkss12
Guest asrequested Posted September 6, 2019 Posted September 6, 2019 (edited) Thanks, I will try that tomorrow. Now it's bedtime. Edit:. That gave me access, thanks. But live TV still does not work. Recordings play fine. Make sure you've allowed access in the user profile Edited September 6, 2019 by Doofus
clarkss12 304 Posted September 6, 2019 Author Posted September 6, 2019 Granddaughter and I went out for breakfast. I had her download and install the Emby app onto her Iphone, and log in using my user name and password with Emby connect. Bingo, she was able to watch everything INCLUDING live TV. I guess my Android phone that I have been using to test for Live TV streaming out of my local LAN, is not up to par........... She was connected using the cellular data. Thanks for everyone's help.............
