aja07 20 Posted September 4, 2019 Posted September 4, 2019 Hi, Tried out Android TV last night and went to start a recording of a single show. I needed to change the trailing padding but on single show/android tv there is no "settings" function. It is there for series recordings. Is this an oversight and will it be included in a later release? Thanks ... Anthony
ebr 16338 Posted September 4, 2019 Posted September 4, 2019 Hi. Yes, this just isn't there yet. For now you can use the web app to adjust it. Thanks.
